August 29, 2026, 10:26:49 am
Hoffman Amps Forum image Author Topic: crackling when playing with bass guitar  (Read 7851 times)
Offline Leevi
    • Rikstone
« on: July 21, 2011, 02:38:44 pm »
I have recently built an SE bass amp which is based on Fender champ
but where 6L6 is used as a power tube and there is SS rectifier. I'm wondering a crackling noise which comes
randomly when playing with bass guitar. The amp is very simple and I have checked
all the possible contact problems. Also tubes have been changed.
/Leevi
Re: crackling when playing with bass guitar
« Reply #1 on: July 21, 2011, 03:22:51 pm »
Separate the head from the speaker by 6 feet or more. Still crackle?
Offline Leevi
    • Rikstone
« Reply #2 on: July 21, 2011, 03:46:10 pm »
The amp is a head and I'm using longer than 6 ft cable. What is your point
regarding the distance?
/Leevi
« Reply #3 on: July 21, 2011, 06:00:27 pm »
vibration maybe shaking a component.
Offline LooseChange
    • Fix Your Darn Amps
« Reply #4 on: July 21, 2011, 08:42:51 pm »
That was my first thought. You can tap the chassis with a rubber mallet and see if you get any noises.
Do you get the noises playing a guitar on the low strings played hard?
I'm wondering if you are hitting the grid too hard. You can add a grid resistor to the preamp gain stages and see if that helps.
Call me Dan
www.fydamps.com
Offline punkykatt
« Reply #5 on: July 21, 2011, 09:35:21 pm »
Im sure you checked the guitar cable and the bass guitar too?
Offline mrm0to
    • Blackbelts
« Reply #6 on: July 22, 2011, 12:49:30 am »
Can I nominate the speaker? This week I saw a Gibson bass amp that had coil rub which was only apparent if you played a bass, sounded fine w/ a guitar.
Offline Leevi
    • Rikstone
« Reply #7 on: July 22, 2011, 01:52:59 am »
That was my first thought. I'm using 1.5k grid resistor on power tube which probably not enough.
I forgot mention that I have an EQ bypass in the amp and the problem exists more often when
the EQ is bypassed.
/Leevi
Offline LooseChange
« Reply #8 on: July 22, 2011, 05:30:45 am »
Put a grid stop on the second preamp stage... 10k-33k. Go big to see if it does anything, then try something smaller to find the smallest, workable value.
I'll assume you tested speaker, jacks and cable.
Call me Dan
www.fydamps.com
Offline Leevi
    • Rikstone
« Reply #9 on: July 22, 2011, 01:18:56 pm »
I'll try this next, cable, speaker, tubes, outputs/inputs have been tested.
/Leevi
Offline Leevi
    • Rikstone
« Reply #10 on: July 22, 2011, 04:02:02 pm »
Actually there is already a grid stop through the vol pot:
http://ampwares.com/schematics/champ_aa764.pdf
The problem exist on a lower volume as well.
The NFB is not used in my amp.
Should I remove the 47 Ohm resistor from the cathode of the 2nd stage?
/Leevi
Offline LooseChange
« Reply #11 on: July 22, 2011, 09:09:30 pm »
Thats not a grid stop and the power tube could use one too.
The grid stop goees diectly on the tube socket soldered directly on the pin.
I don't think removing the 47r will make much difference but you should try the NFB.
Call me Dan
www.fydamps.com
Offline Leevi
    • Rikstone
« Reply #12 on: July 23, 2011, 09:56:43 am »
Unfortunately the grid stopper didn't help but I made a new observation:
When I repair the amp it's up side down and the problem never comes up.
If the amp is in its normal position it starts to crackle. This happen
with a Tung Sol's 12AX7. With a new JJ I don't get it crackle any more.
However the guy who is using the amp mentioned that it has also happened with the JJ.
I believe that the Tung Sol is now faulty but could it possible that the amp has damaged the tube
with wrong settings especially when playing with a bass guitar?
That could be the clarification that the same has happened with a JJ as well.
/Leevi
Offline Leevi
    • Rikstone
« Reply #13 on: July 31, 2011, 08:41:02 am »
I think the problem is solved now. It had nothing to do with the tubes. The
reason was the push/pull volume pot (made by Alpha). I'm not sure which one caused the problem
the switch or the pot part but anyway I succeeded to localize the problem with a chopstick.
/Leevi
Offline bluesbear
« Reply #14 on: July 31, 2011, 02:05:57 pm »
Good for you! That's the trickiest kind of problem to track down.
Dave
