September 21, 2026, 07:37:49 pm
Hoffman Amps Forum image Author Topic: 6J6A Long Tail Phase Inverter.  (Read 5771 times)
« on: September 17, 2011, 04:27:45 pm »
any ever try using a 6J6 for a long tail? would any of you even consider it?
here's what i was thinking...
75K Ra1
91K Ra2
1K2 Rk
10K Rtail
1K   Rtail-nfb
RNFB - to taste...
about 3mA bias sitting around -4Vgk.
should make about 70Vpk into 220K loads.
thoughts?
thanks in advance for any input.
peace.
--DL
Re: 6J6A Long Tail Phase Inverter.
« Reply #1 on: September 17, 2011, 08:18:11 pm »
never mind.
tube does not sound good for guitar amp use - maybe in hi-fi it would find a better home. tried a wide range of bias points and i liked none of the tone. reverting to the 6AV6 cathodyne.
peace.
--DL
Offline Tiny_Daddy
  • Get your Amp N Gear!
« Reply #2 on: September 17, 2011, 08:45:17 pm »
Also notice the 6J6 draws the same filament current as a 6V6 power tube.
« Reply #3 on: September 17, 2011, 09:39:45 pm »
9W tube - should draw some fil. current. 6SN7 draws even more - 600mA, i doubt that's only reason it hasn't worked out well for me for guitar amp use.
