September 19, 2026, 09:16:26 am
Hoffman Amps Forum image Author Topic: Low power Orange OD120  (Read 5743 times)
Offline chocopower
« on: September 19, 2011, 09:24:36 am »
Hi there!
I´m working with an Orange OD120  (4xEL34) that with volumen and master volumen on 10 has less power than my 2 6V6 amp.
Voltages on power tubes are pretty high and seems ok.
After play it for ten minutes, two of the power tubes get redplating (left side ones).
i have to check the bias and install a new set, just for eliminate posibilities, but i dont think the redplating can produce the low power problem.
my next step is check the coupling caps after the P.I.
any other idea?
thanks in advance.
« Last Edit: September 19, 2011, 10:35:53 am by chocopower »
David
Offline chocopower
Re: Low power Orange OD120
« Reply #1 on: September 20, 2011, 06:59:23 pm »
David
« Reply #2 on: September 21, 2011, 07:46:08 pm »
Low output AND redplating means you really have to go through EVERYthing.
If your car was slow and overheating, it could be spark-plugs, spark timing, soot in the pistons, fuel injectors, dragging brakes, bad wheel bearings, trash on the radiator.......
Offline chocopower
« Reply #3 on: September 21, 2011, 08:13:17 pm »
thanks,
that was i affraid...
« Last Edit: September 21, 2011, 08:59:34 pm by chocopower »
David
Offline scarlett amps
    • Scarlett Amplification
« Reply #4 on: September 23, 2011, 08:38:51 am »
Sounds like it could be the ot. Do this and check it out.Marshall trafo de saída
Offline chocopower
« Reply #5 on: October 31, 2011, 10:50:06 am »
i think is the OT too..... :BangHead:
I open the amp and found damages in bias circuit and diode rectifier bridge. Several diodes burned and some resistors out of range.
After make a complete rebuild of those areas and check the hole amp, the problem still is there...
I´ll check the OT next week and come back with the results...
David
Offline chocopower
« Reply #6 on: November 18, 2011, 12:23:48 pm »
One question?
I have a trafo with 34v secondaries. Is safe put those 34v into the secondary to measure it in the primaries or should i use a lower voltage?
David
