September 16, 2026, 02:58:28 pm
Hoffman Amps Forum image Author Topic: Which Oscilloscope probe to use on high voltage?  (Read 11488 times)
Offline six el six
« on: November 20, 2011, 02:53:24 pm »
I'm going to experiment w/my o-scope tonight (tektronix 2235).
Do I use my 10x probe?
Apparently I want to stay under 4oov so I'm wondering does the 10x probe allow me to see the waveform on plates and other high voltage areas of amps?
Offline six el six
Re: Which Oscilloscope probe to use on high voltage?
« Reply #1 on: November 20, 2011, 03:29:01 pm »
I think I've answered my question.
If I'm trying to see the ac waveform of say, a power tube plate, then a 10x probe will effectively give me 1/10 of say, 450 v dc plate voltage in which case I'll be well within the limits of <400v peak.
Correct?
« Reply #2 on: November 20, 2011, 06:17:14 pm »
Yes I think you are right.  See:  http://www.tek.com/Measurement/App_Notes/tds360-p5100/eng/40W_11343_0.pdf
But Murphy's Law is always lurking.  If the probe is accidentally set to X1, you may damage the scope.  Another solution is to read the plate's AC signal through a large plastic cap, say .22uF or larger with a proper voltage rating.  That will block the high DC voltage to protect the scope, and should allow the full AC signal to pass to the probe.
« Reply #3 on: November 20, 2011, 09:19:44 pm »
No. The compensation cap in a 10:1 probe is rated 500V. If you apply more than 550V to the probe, this cap ARCS and ruins the probe.
So you may be able to monitor all the low-level stages, and the power stage plates at NO SIGNAL, but with any significant signal a typical 400V amp will be kicking the power tube plates over 550V, ZAP.
I used to have a collection of zapped probes.
If you must monitor power tube plates, build a dedicated divider. 10Meg:100K will reduce 700V kicks to 7V. Frequency response extends to 50KHz which is ample for our purposes. A 1X 1Meg probe across the 100K will cause 10% calibration error, but we are mostly interested in "shape", not absolute measures. 10X 10Meg probe across 100K gives only 1% error. You can calibrate by comparing idle voltage with DMM.
