September 20, 2026, 12:06:01 pm
Hoffman Amps Forum image Author Topic: Channel switching in a B.Face Twin Reverb clon  (Read 4291 times)
Offline chocopower
« on: November 20, 2011, 03:26:10 pm »
Hi.
I friend is asking me for channel switching in his Twin Reverb.
I have some SPST relays and want use them for the job.
The "normal" channel imputs will be the imput for boths channels. From there, it will go to the relay common pin.
It switch betwen the 2 sides of the SPST sending the signal to the imput grid of V1 or V2.
ok. the question. Can i leave the "unused" channel without grid leak reference?
I supose that shouldnīt, but i like to ask...
If not. i suposse i should use DPDT relays to ground the grids...
thanks in advance and sorry for my english. I had some problems trying to puit in words my question..
David
Re: Channel switching in a B.Face Twin Reverb clon
« Reply #1 on: November 20, 2011, 05:42:46 pm »
something like what i attached what you have in mind? i'm thinking you'd want to mute the unused channel.
--DL
Offline chocopower
« Reply #2 on: November 21, 2011, 02:25:53 am »
thatīs right.
Grid and grid leak resistors before the relay area. I think i can do it with a simple DPDT relay.
thanks a lot!
David
Offline chocopower
« Reply #3 on: November 22, 2011, 02:27:54 am »
hi there.
is working. Now, i just want to add a led to the footswitch using the same voltage used to activate the relay.
Is posible? Wich way?
i use that schematic:
David
