September 20, 2026, 08:56:40 am
Hoffman Amps Forum image Author Topic: Plexi screen resistors- 2 watt okay?  (Read 6819 times)
Offline Madison
  • What's up slobbies?
    • Funky Dolphins
« on: November 21, 2011, 07:43:33 am »
Can I get away with using these 1K/2W on the EL34s?
I installed them but just want to be sure.
I don't have any 1K/5W here.
I do have 1.5K/5W.
« Last Edit: November 21, 2011, 08:02:24 am by Madison »
Re: Plexi screen resistors- 2 watt okay?
« Reply #1 on: November 21, 2011, 08:51:03 am »
I think so. A 1K resistor would have to see 45ma to dissipate 2 Watts, or 31ma to dissipate 1 watt.
Offline jim
« Reply #2 on: November 21, 2011, 09:27:03 am »
I would use the 1.5 K 5W.  It is safer and the amp won't know the difference.  Jim
Offline Madison
    • Funky Dolphins
« Reply #3 on: November 21, 2011, 05:39:42 pm »
Thanks!
I'll probably try set the bias so it can't adjust that high.
I am estimating about 400 volts on the plates with this amp.
42ma would be the max dissipation a guy would want to adjust to, I think?
Doesn't the increased value reduce overall output?
And/or tone?
Offline Cups
« Reply #4 on: November 21, 2011, 05:59:17 pm »
I don't think you'll be able to hear the difference in volume or tone. Could be wrong though. Why not try it out? Those are robust resistors and it's an easy enough swap.
I know I'd stick with the 5W but I'm cautious that way.
« Reply #5 on: November 21, 2011, 06:12:26 pm »
You're thinking plate dissipation. Screen dissipation is much less, typically only about 10% of plate dissipation.
Fender used 470Ω/1W screen resistors on most all of their amps, big and small. 'Course I've seen several scorched screen resistors in Fender amps.  :icon_biggrin:
Offline LooseChange
    • Fix Your Darn Amps
« Reply #6 on: November 21, 2011, 09:54:18 pm »
The standard screen resistor for an el34 is 5 watts. Use the 1k5. You'll never hear the difference.
« Last Edit: November 22, 2011, 05:20:25 am by LooseChange »
Call me Dan
www.fydamps.com
Offline Madison
    • Funky Dolphins
« Reply #7 on: November 21, 2011, 10:31:28 pm »
Thanks, LC.
I think I'll go for it.
I can't jeopardize my magic smoke.
Now that darn Sluckey.
That guy, he just left me hanging!
I mean good golly, I had to go out and read pages and pages about screen resistors and learn something new!
Oh......my head
Thanks again Gents. :notworthy:
Offline bigsbybender
  • Hack Of All Trades
    • Tube Amp Gallery
« Reply #8 on: November 21, 2011, 10:37:43 pm »
I tried 2w with EL34's with a plexi-ish amp I built and they turned brown, so I switched to 5w resistors. I have ever since on any amp I build that can take EL34.
Open Minded But Fixed Bias
Offline Madison
    • Funky Dolphins
« Reply #9 on: November 21, 2011, 10:41:25 pm »
I figure the draw of 6L6s must be at the borderline for 1 watts?
Swapping them out right now.
