August 06, 2026, 08:17:36 pm
Hoffman Amps Forum image Author Topic: replacement transistors ?  (Read 12146 times)
Offline worth
« on: November 22, 2011, 06:19:36 am »
I need to find replacement output transistors for a Peavey XM4 powered mixer. One is a Motorola SJ8227 MEX 8721.... the other is Motorola SJ226 MEX 8720. Peavey support hasn't responded to my e-mail.
Offline firemedic
Re: replacement transistors ?
« Reply #1 on: November 22, 2011, 06:34:36 am »
Check Mouser.com, if you don't see the part #s then call their customer support # and they may be able to get what you need.
« Reply #2 on: November 22, 2011, 10:00:57 am »
SJ-8227 *74140 Motorola MJ-15053  70474140  PNP 140V OUTPUT
SJ-8226 *84140 Motorola MJ-15052  70484140 NPN 140V OUTPUT
link to Peavey x-sistor x-ref
http://www.scribd.com/doc/29319120/Peavey-Semiconductor-Cross-Reference-List
mouser sells NTE.
NTE replacement NTE68 for the MJ-15053
NTE replacement NTE388 for the MJ-15052
respectfully, this should have been posted in solid state...
--DL
Offline worth
« Reply #3 on: November 22, 2011, 03:49:10 pm »
Thanks Dummy... that's what I needed.
Offline worth
« Reply #4 on: November 22, 2011, 05:41:43 pm »
Can someone explain the testing procedure for this transistor.. I know this post should be in "solid-state", but nobody would see it.
« Reply #6 on: November 22, 2011, 06:32:19 pm »
Worth this is a very good video and explanation of PNP & NPN transistors and how to test them and more
Transistor Testing, the Basics
