September 15, 2026, 12:21:38 am
Hoffman Amps Forum image Author Topic: 1 X 12AX7 killer stompbox schems needed  (Read 8214 times)
Offline Colas LeGrippa
  • MAKE LOVE NOT WAR
« on: November 23, 2011, 05:28:23 pm »
In fact, I have already built it, cool unit, clean overdrive, not noisy at all. The problem is that I crave heavy metal sound and this unit suffers from a lack of..nice distortion. I just can't understand how to chieve a GOOD distorted tone. I have been swapping cathode caps and resistors, from 820 to 15K and from .68 to 330uF  without good results. The max voltage I got at the plates is 120V.
Help.........!
Colas
P.S.: call me Alvin.
Offline chocopower
Re: 1 X 12AX7 killer stompbox schems needed
« Reply #1 on: November 23, 2011, 08:34:03 pm »
Can you post a schematic?
I have a vintage Guyatone TO-2 with a 12AX7 inside and REAL tube voltages with a nice "tubescreamer" sound.
that schematic is like mine, but without tonestack (mine have bass-treble controls)
http://www.freeinfosociety.com/electronics/schemview.php?id=985
David
« Reply #2 on: November 23, 2011, 08:55:01 pm »
Do a google search for "The Real Mctube". Maybe that will work for you.
http://www.dogstar.dantimax.dk/tubestuf/mctube.htm
Offline terminalgs
« Reply #3 on: November 23, 2011, 09:15:46 pm »
google 'matchless hotbox'  and look at those schematics.   If you are familiar with the fulltone OCD,  the matchless hotbox is that area of distortion.
also,, if you are looking for a tube version of a 'fuzzface' or a 'boss metal zone' pedal,  its not going to happen with a single tube (or 2 for that matter).
Offline RicharD
    • Toxic Water
« Reply #4 on: November 24, 2011, 12:04:42 am »
Notice in the schematic sluckey posted how frigid the bias is.  Hi gain, low current.  Traditional Fender values won't do what you want it to do.
  • MAKE LOVE NOT WAR
« Reply #5 on: November 24, 2011, 05:49:37 am »
Hi ! First, thanks for your replies.. I do not have any schems of the stompbox I have built  since it so simple to imagine and to build, I did not take the time to draw a so stupid thing...( stupid but hard to tweak..hey hey ). I looked at the real mctube and the plate resistors values seem very high ( maybe i should experiment with extra-ordinary values............). The other one, posted by Chocopower looks very interesting........one question, Mr Chocopower : what is the purpose of the 2 diodes ( 1n914 if I remember well) from the last coupling cap back to the first cathode ? They are fast switching diodes and I just can't figure out what they're doing there.
Best regards
Colas LeGrippa
« Reply #6 on: November 24, 2011, 06:13:21 am »
The diodes clip the positive and negative peaks on the signal, and that kinda squares up the signal. A square wave is full of harmonics and sounds very distorted/fuzzy. Many commercial distortion units use the back to back diodes.
  • MAKE LOVE NOT WAR
« Reply #7 on: November 24, 2011, 06:25:57 am »
cool ! I"ll do the mod with the diodes and get back later when it's done with the results !
thanks for the explanations
Colas
Offline terminalgs
« Reply #8 on: November 24, 2011, 09:20:51 am »
Colas
for more reading on clipper circuits:
http://www.allaboutcircuits.com/vol_3/chpt_3/6.html
note that the DC voltage on the cathode of V1 plays a part in where the AC  signal is clipped.
« Reply #9 on: November 24, 2011, 01:24:09 pm »
One that I've built several of is the PAIA Stack-in-a-Box.  It uses 1 12AX7 and starves the plates.  Lots more stuff going on in there with some really nice features.  Effects loop, filter switches, xlr out.  I think it sounds really nice, shimmer to grind.  Uses a couple of 5532 opamps to keep things quiet.  Nice rack mount too.  Probably cheaper to buy the kit than to piece it out.  I actually built one of these into a Firefly that I built for a guy, turned out really cool.
Kit
http://www.paia.com/proddetail.asp?prod=9210K
Schematic
http://www.paia.com/prodimages/siabsch.pdf
  • MAKE LOVE NOT WAR
« Reply #10 on: November 25, 2011, 11:39:46 am »
Thanks to all !
Colas LeGrippa
