September 18, 2026, 05:51:43 am
Hoffman Amps Forum image Author Topic: 6L6's in a Deluxe Reverb  (Read 4605 times)
« on: December 19, 2011, 08:17:04 pm »
What do you guys think about running 6L6's in a stock DR. The PT filament winding is rated at 3 amps. Isn't that a little iffy?
Offline P Batty
  • Flippism Is The Key
Re: 6L6's in a Deluxe Reverb
« Reply #1 on: December 19, 2011, 09:23:22 pm »
I've had 5881's in mine for three years now, although it's just a bedroom amp.  (.9a x 2) +(.15a x 5) = 2.55 amps, might be a bad idea in the long run, but that seems to be a reasonable margin to me.
Offline alerich
  • This one goes to 11.
« Reply #2 on: December 19, 2011, 09:52:48 pm »
I ran one like that for a while. As I recall the PT ran a bit warmer but it didn't suffer any failures.
stratele52
  • Guest
« Reply #3 on: December 20, 2011, 03:44:14 am »
If your heater voltage is over 6 volts with the 6L6 , power transformer is enough powerfull. Normal is 6.3. If under 6 volts, remove your 6L6.
6L6 give a cleaner tone.
