September 19, 2026, 12:06:25 am
Hoffman Amps Forum image Author Topic: unknown effects switch  (Read 7520 times)
Offline mrpeters
« on: January 30, 2012, 12:07:44 pm »
i have a 4 button effects switch.going from left to right the switches are:echo,rotating sound,reverb,tremolo.there are red led's above swiches.the plug-in looks like the base of a large vacuum tube.it has 8 pins which are steel and a larger center pin which is plastic.any info at all would be very helpful.thanks!mike peters.
« Last Edit: January 30, 2012, 08:25:47 pm by mrpeters »
Offline LooseChange
    • Fix Your Darn Amps
Re: unknown effects switch
« Reply #1 on: January 30, 2012, 04:56:05 pm »
A picture is worth a 1000 words.
Call me Dan
www.fydamps.com
Offline stingray_65
« Reply #2 on: January 30, 2012, 08:23:09 pm »
What is it you want to know?
Where did it come from?
Do you have an ohm meter and know how to use it?
OH! and what LooseChange said! pics help us help you a lot!
