September 25, 2026, 10:47:44 pm
Hoffman Amps Forum image Author Topic: 1965 Vox ac30 hum...  (Read 5804 times)
Offline bruno
  • got to love that glow
« on: February 28, 2012, 06:42:33 am »
My vox ac30 still has some hum, while playing I doesn't really bother me too much, recording however is a problem.
I've changed the original filter caps, for new ones, but kept the same low values, as I feel that is part of how the amp feels and responds. I've also cut the heaters ground wiring which was done directly to the chassis, and used two 470ohms resistors to create a virtual center tap (might change to two 100ohms, but I didn't have them at hand).
the amp still has a reasonable amount of hum which obviously increase as volume does. I haven't started to change the power supply resistors (which probably have drifter somewhat in value), would that help?
Any other sugestions?
thanks
Offline rzenc
  • TUBES RULE
Re: 1965 Vox ac30 hum...
« Reply #1 on: February 28, 2012, 07:55:08 am »
Divide and conquer bro!
Take the P.I. tube out and check if it still hums...if so.. hum source might be after P.I.
P.S.: Check ALL ground tie points...had some hum issues going on due to inconsistent ground
