September 15, 2026, 04:19:12 am
Hoffman Amps Forum image Author Topic: circuit for a low wattage amp  (Read 4780 times)
Offline Leevi
    • Rikstone
« on: March 17, 2012, 05:55:52 am »
I'm looking for circuit for a low wattage (1-2W) amp.
Would it work in a known SE amp (like Champ) if triode mode is
used instead of tetrode mode?
/Leevi
Re: circuit for a low wattage amp
« Reply #1 on: March 17, 2012, 06:54:08 am »
My suggestion would be to use a VVR with a single ended amp like a Champ or the SoLow Watt.  The VVR is only $30 and very easy to install.
http://www.el34world.com/Forum/index.php?topic=6899.0
Offline Leevi
    • Rikstone
« Reply #2 on: March 17, 2012, 01:26:03 pm »
That's fully true Tubenit. A VVR makes that possible, even dynamically.
Is it enough to use VVR only for the power tube?
/Leevi
Offline Leevi
    • Rikstone
« Reply #3 on: March 17, 2012, 05:41:33 pm »
I found this:
http://www.el34world.com/Forum/index.php?topic=7413.msg65728#msg65728
Can there be used some other Mosfets if the current and voltage specs are fulfilled?
/Leevi
« Reply #4 on: March 17, 2012, 07:46:04 pm »
Leevi,
I have pretty limited knowledge of the VVR.  I think I've used them in 4 different amps with success but I always used Dana Hall's VVR which is inexpensive and easy to install.
You'll have to sign up to see the schematics, but I think there are numerous VVR schematics for single ended amps here:
http://www.wattkins.com/vvr
