September 08, 2026, 08:21:14 pm
Hoffman Amps Forum image Author Topic: 5E3 works after 1 hour playing  (Read 5006 times)
Offline Leevi
    • Rikstone
« on: April 01, 2012, 12:49:01 pm »
I got a question regarding 5E3. There is some kind of power loss and
the amp starts work about one hour playing. Any ideas where to start to troubleshoot?
Power tubes have been changed.
/Leevi
Re: 5E3 works after 1 hour playing
« Reply #1 on: April 01, 2012, 02:32:37 pm »
When you first turn the amp on .................. take voltages.   After an hr of playing when the volume is "right"  ............. take voltages again.   Any difference?
Look for bad solder joints.  Triple and quadruple check every connection and solder joint.
My guess is something is expanding from heat and improving contact allowing better power.
with respect, Tubenit
Offline archaos
« Reply #2 on: April 01, 2012, 02:42:44 pm »
Yep, +1, & perhaps particularly bad solder joints as regards the speaker plugs if you used flat plugs.
I have stopped being surprised at the guitar player who spends $3,000 on the latest boutique amplifier, and plugs in his Mexican Stratocaster strung with light gauge strings through a Big Muff Pi fuzz pedal.
Mehr Licht !
Offline Leevi
    • Rikstone
« Reply #3 on: April 01, 2012, 02:45:24 pm »
Unfortunately the amp is not by me right now.
The amp is first very bass sounding and needs more more volume than normally.
I was thinking if a coupling capacitor could be the reason?
/Leevi
Offline Leevi
    • Rikstone
« Reply #4 on: April 02, 2012, 02:48:31 pm »
I got the amp and tested it but I didn't get problem repeated  any more.
I found a partly open flat speaker plug which could have caused the problem.
/Leevi
Offline archaos
« Reply #5 on: April 06, 2012, 04:09:25 pm »
/Leevi
Cool if you found the culprit.
Mehr Licht !
