September 08, 2026, 10:32:40 am
Hoffman Amps Forum image Author Topic: Deluxe-umble Reverb idea  (Read 15706 times)
« on: April 11, 2012, 07:13:11 am »
I was thinking about how much I like the clean tone of the Tweed BluezMeister, but that it would be cool to have reverb and vibrato like on a Deluxe reverb.  So this is what I came up with.  Haven't built it, but I'd love to.
CHECK for errors!!  Any discrepency, go with the schematic which should be correct.
IF you don't want to use a phase invertor plate 10k trim pot, then I'd suggest using a 120k & 110k resistor for the plates.
* Edit    added Dumbly DR which does not have an active FX. However, be sure to check for discrepencies between schematic and layout.  IF there is a difference, go with the schematic drawing.
« Last Edit: July 25, 2013, 09:00:21 am by tubenit »
Re: Deluxe-umble Reverb idea
« Reply #1 on: April 11, 2012, 08:32:38 pm »
At the risk of being dumb, which Deluxe reverb circuit did you decide to follow
Technically, none of them. I am simply adding a reverb circuit and a vibrato circuit like Deluxe Reverb AB763 has. And even the reverb & vibrato are not the same.  I also used a tube rectifier unlike a D-style amp but similar to a DR.  And it uses a fixed bias 6V6 power amp like a DR.
« Last Edit: April 12, 2012, 06:48:38 am by tubenit »
Offline Tom_Hull
« Reply #2 on: April 11, 2012, 09:35:22 pm »
hi
just learning ,,
6v6
does pin 8 ground need a resistor and cap
like 25uf 25v ,,,, 250 ohm ,10 watts
tom
« Reply #3 on: April 12, 2012, 05:04:33 am »
6v6
This amp is fixed biased instead of cathode biased. So no, it doesn't need a cathode resistor and cap. You could build a cathode version if you wanted but the vibrato circuit would need to be modified.
Offline Tom_Hull
« Reply #4 on: April 12, 2012, 06:08:49 pm »
thanks for the answer..
now back to  more reading and studying .... ..
and getting ready for this amp later next month ....and i bought some 12AT7 s this morning
tom
« Last Edit: April 12, 2012, 06:57:35 pm by Tom_Hull »
« Reply #5 on: April 12, 2012, 08:11:41 pm »
Check v2 for validity.  I noticed this valve had two triodes in parallel.  Care to discuss this approach?
The approach is the standard that Fender uses on all their Fender reverb circuits .
Check out a schematic  Princeton Reverb, Deluxe Reverb, Super Reverb, Twin Reverb ................ etc.......
Offline Tom_Hull
« Reply #6 on: April 23, 2012, 08:02:33 am »
hi
well i have been looking and wondering about V4.
should ...........
16 ,,,,,,,,,,1M to ground line .
15 ,,,,,,,,,,,wire to bottom 16
               1M
pin 3  V1        4.7 M resistor to ground
heres a pic
thanks
tom
« Last Edit: April 23, 2012, 08:05:47 am by Tom_Hull »
« Reply #7 on: April 23, 2012, 09:25:18 am »
I don't understand what all your questions are?
Go with the schematic if there is an error between schematic and layout.
There should be a 4.7M resistor to ground from the .002 to mid-boost switch on the layout.
Remember, this is a DRAFT idea. As far as I know, no one has built this.
« Reply #8 on: November 29, 2015, 02:08:12 pm »
This is closer to a Deluxe Reverb then Dumblish.   I like cathode biased amps because I can simply substiture a 6V6, 6L6, or 5881 with NO changes.
The idea was to dumblize the DR tone stack.  On my Tweed BluezMeister on clean using the midboost and PAB,  it is almost the same overdrive/gain as with the OD channel engaged.  Not as much but headed there.
So this idea would allow a DR with reverb and vibrato, cathode biased and a D-style tone stack.  Note some other values and coupling caps are changed to make this more D-style friendly tonally.
CHECK for errors!  IF there is a discrepancy, go with the schematic.  This is a DRAFT idea, I have not built it.  IF you build it, you might consider using a 300R/10w resistor and a 100uf cap for the power tubes.
