September 15, 2026, 07:30:03 am
Hoffman Amps Forum image Author Topic: 5c1 with 6au6 & 6aq5 - can I use a 6x4 as rectifier ? 310v AC are enough ?  (Read 9865 times)
I think I can build a 5c1 champ using 6au6 in place of 6sj7 and 6aq5 in place of 6v6
can I use a 6x4 as rectifier tube in place of the 5y3 ?
the 70mA of the 6x4 are enough for the 5c1 ?
310v AC (80mA) are enough ?
Kagliostro
« Last Edit: May 29, 2012, 01:26:46 pm by kagliostro »
So it will be better I go a step back and build it with SS rectifier (as you told, no 5v winding, if I don't find one other PT)
Kagliostro
I've find this, but don't know if this can be mod as guitar amp without heavy mods
http://www.retrovox.com.au/03556AQ5.pdf
Kagliostro
« Last Edit: May 29, 2012, 01:23:35 pm by kagliostro »
The 6X4 can handle 70ma of dc current which should be plenty for a 6AQ5 and 6AU6. All three tubes can be heated from the same 6.3VAC winding.
Thanks Sluckey
Kagliostro
yes.
with 6AQ5 idle set to 9W with 310V you'll need ~35mA + screen and pre-amp - another 8-10ma worst case.
yes.
it's class A single tube. ditch the vacuum recto and go SS - you won't notice any diff. in tone, however, with SS recto, you can kick up the filter size considerably and improve audible PS "buzz" at idle.
--DL
Hi DummyLoad
thanks for clarifications
my transformer is 310v AC is this too high if rectified SS ?
My quick research shows that 6X4 & 5Y3 both max out at 10uF for the 1st filter cap.  I suspect, but cannot prove, that such a low value contributes to overall muddy tone.  Personally, I would keep the tube recto > 10uF cap "pre-filter stage" > dropping resistor > say 40uF "1st filter stage" > plate, etc.  The dropping resistor's main function is to isolate the "pre" from the "1st" filter stages.  It's value could be chosen to precisely target your desired plate voltage under load.
SS will yield 438VDC unloaded. That PT is probably too high for the 6AQ5 even with a tube rectifier.
Thanks JJasilli & Sluckey
I think I'll go for one other PT
Another solution is a 12V bucking transformer.  It should knock the wall voltage down by 12.6V.  The PT converts 120VAC in, to 310 out.  310/120 = a factor of 2.583;  120VAC - 12.6 = 107.4VAC X 2.583 = 277VAC X about 1.1 conversion factor for the little bottle tube recto = 305VDC!!! Not bad, especially if dropping resistor is added (per above post).
Very interesting link
Thanks DummyLoad
« Last Edit: May 30, 2012, 01:14:10 am by kagliostro »
