September 12, 2026, 09:23:34 pm
Hoffman Amps Forum image Author Topic: Oscilliscope Question  (Read 5562 times)
Offline Davidg
« on: July 04, 2012, 12:01:38 am »
I apologize if this should be in tools sectionbut I need an oscilliscope and know nothing about them.What can I expect to pay for a decent 20mhz scope?
       Can I get by with 10mhz?
      Just because a scope lights up and makes a wave is it functional ? cause there are alot of cheap ones on ebay that the people say they cant test them cause they dont know how,dont have probes etc...
         Anyone know a better place than ebay to get a cheap-o?
Offline archaos
Re: Oscilliscope Question
« Reply #1 on: July 04, 2012, 03:22:57 am »
I got an Owon PDS5022S through eBay in 2010 & it works flawlessly. http://www.owon.com.cn/eng/pdsSeries.asp
I have stopped being surprised at the guitar player who spends $3,000 on the latest boutique amplifier, and plugs in his Mexican Stratocaster strung with light gauge strings through a Big Muff Pi fuzz pedal.
Mehr Licht !
stratele52
  • Guest
« Reply #2 on: July 04, 2012, 03:30:41 am »
Buy a Tektronix , this is one of the most tough 'scope. I have the 2215 model . Be sure they have probe in working order .
Price ? $100 to $200
Scope parts could be hard to find, so buy a good one IN working order.I see some jober's probe at my electronic store , $30 , I don't if they are good.
stratele52
  • Guest
« Reply #3 on: July 04, 2012, 03:33:45 am »
Read amp tool / tech tips section on oscilloscope, there are some answer for you.
http://www.el34world.com/Forum/index.php?topic=13536.0
Offline thelonious
  • t00b n00b
« Reply #4 on: July 04, 2012, 10:02:17 am »
+1
If you're patient you can get good deals on eBay. I got an older Tektronix 465B in good condition with 2 probes and manual for $122 + shipping cost, and I've been very happy with it. I wouldn't buy one from a seller who didn't know how to test it---that would be a crapshoot, and 'scopes are complicated critters. On the other hand, you don't have to buy a scope that has been calibrated, certified, signed by Michael Jordan, and blessed by il Papa. Look for listings where the seller has described the condition confidently and shows photos of actual trace(s) being produced on the scope by a function generator. That won't guarantee a calibrated (or even completely working) scope, but it's better than "I don't know how to test it", and far less expensive than a calibrated one. For amp use, we're mostly interested in finding p-p signal voltage and looking at distortion on sine waves anyway.
For cheaper alternatives and skipping the shipping, find a hamfest near you this summer.
« Last Edit: July 04, 2012, 10:06:11 am by thelonious »
Offline Davidg
« Reply #5 on: July 04, 2012, 11:18:25 am »
Thanks Guys! I guess I was hoping to get off too cheap and find one for $100.I have actually seen some Techtrx scopes for around $150 shipped so I guess I will go ahead and pull the trigger on one.I wish there was a hamfest near me but I am in the stix and the ones I have found are 2-5 hours away and I just dont have time.
        Do the probes have to be matched to the bandwidth of the scope or something?
         Is it not a good idea to buy aftermarket probesor should I be looking for one with probes just to be sure I get a good set?
stratele52
  • Guest
« Reply #6 on: July 04, 2012, 04:53:22 pm »
I found mine on" Craig List"  close to my home so I can see it working
« Reply #7 on: July 05, 2012, 08:51:16 pm »
So how can you know you "need" a 'scope?
I did a heap of good work with a "450KHz" (0.45MHz) 'scope. Gas-sweep!
I once, on-purpose, re-built a (junked) 'scope for 20KHz bandlimit (0.02MHz).
My current 'scope was pulled from a rain-soaked pile. Has a backhoe-bite in the top. H-P rackmount with (again) 0.45MHz bandwidth (true trig sweep, but again gas-tube calibration).
I do have a handheld. somewhere, which may be 1MHz.
While a 20MHz _might_ be useful in transistor audio, very-very few people would know what to do with those extra 19MHz.
Just in passing.... I saw this while looking for something else:
http://www.electronickits.com/gold/CKOSCOPE10MHZ_Low_Cost_10MHZ_Oscilloscope.htm
10MHz Oscilloscope -  $179.95
Single channel, and dual-channel is occasionally very useful. However X-Y mode is right there (no back-panel hacking) and will do many of the same things (plus do Lissajous, handy for entertaining stoners).
Under two-hunert from a savvy vendor fully warranted may be better than putzing around with "untested" too-fancy used 'scopes missing probes.
They also have a handheld (buck cheaper), and a dandy function generator for forty bucks kit.
