June 13, 2026, 03:41:13 am
Hoffman Amps Forum image Author Topic: 5E3 Power tansformer  (Read 4811 times)
Offline Leevi
    • Rikstone
« on: July 04, 2012, 05:05:01 pm »
I got a 5E3 wired and wonder the specs of the recommended 5E3 PT
where the secondary is on level 330-0-330. I think the optimal B+ is about 380V that many
have reached by using the recommend transformer?
I met last time problems with too high B+ and that's why I selected this time a PT with 275-0-275
secondary. The B+ is now 370V with Sovtek 5Y3GT rectifier.
What could be the reason that big difference?
- 230V/50Hz vs. 117V/60Hz
- better transformers
/Leevi
Offline Tyrannocaster
Re: 5E3 Power tansformer
« Reply #1 on: July 04, 2012, 08:36:22 pm »
I don't think it's the transformer.
The Sovtek 5Y3 isn't really a 5Y3, from what I have read. If you have another brand (an old NOS would be nice) try that instead - your voltage should be a lot lower. I tried using a Sovtek 5Y3 in one of my amps and the B+ was considerably higher with it than with an old real 5Y3, but that was several years ago and I don't remember exactly how much too high it was; as I recall, it was about the same as a 5AR4. I thought that by now they would have started making them to spec but it sounds like they haven't.
Rautalanka kaiku!  :icon_biggrin:
Offline Tiny_Daddy
  • Get your Amp N Gear!
« Reply #2 on: July 04, 2012, 08:49:51 pm »
I agree, the Sovtek 5Y3 has a lower than expected voltage drop for a 5Y3. Seems more like they used 5AR4/GZ34 guts?
Offline Leevi
    • Rikstone
« Reply #3 on: July 05, 2012, 12:52:21 am »
The rectifier tube can affect on this but doesn't clarify everything. I guess the
second reason is the transformer which doesn't drop the voltage with higher load.
Link to my previous topic of this item:
http://www.el34world.com/Forum/index.php?topic=11378.0
Another question is the the cathode resistor of the power tubes.
I increased it from 250 Ohm to 560 Ohm in order to get the cathode current (per tube) to
an acceptable level i.e. to 23mA.
/Leevi
« Reply #4 on: July 05, 2012, 06:23:39 am »
Raising the cathode R value will usually increase the B+ as well.
If your PT is robust in the current capacity department, maybe that is why the voltage isn't dropping as much under load? I dunno, just a thought. Anyway, if your PT is 275-0-275 then 385  B+ is about right (before rect. tube). Those new "5Y3s" only drop about 30 volts, just depending.
Offline Leevi
    • Rikstone
« Reply #5 on: July 05, 2012, 08:46:00 am »
Yes, that's true and I checked this with several resistor values. The variation was
max 10V on the lowest and highest resistor value I tested.
/Leevi
