August 04, 2026, 12:56:25 am
Hoffman Amps Forum image Author Topic: Boost foot switch hum problems  (Read 4649 times)
Offline Madison
  • What's up slobbies?
    • Funky Dolphins
« on: July 27, 2012, 01:59:50 am »
When I turn on the boost this hums like crazy.
I have tried grounding it different ways; on the input jack, via the foot switch jack.
Nothing seems to help.
About the only thing I haven;t tried is an insulated input jack.
Where have I gone wrong?
Re: Boost foot switch hum problems
« Reply #1 on: July 27, 2012, 02:39:13 am »
Does the boost hum when you engage it from the amp's control panel switch (as opposed to using the footswitch)?
Offline jeff
  • Need input
« Reply #2 on: July 27, 2012, 05:01:51 am »
What is this switch actually doing? I don't understand the circuit. Could you show how it's connected to the cathode bp cap(rest of the cicruit)?
Offline Madison
    • Funky Dolphins
« Reply #3 on: July 27, 2012, 07:50:33 am »
Oh, this does have a CT on the 6.3 taps from the PT.
Sorry forgot to add it.
« Reply #4 on: July 27, 2012, 08:24:48 am »
Put a filter cap on the rectifier output (470-1000uF). Even better, use a double pole switch. One pole switches the bypass cap, the other pole switches the LEDs. Or even more better, drop the idea of the LEDs altogether.
Offline Madison
    • Funky Dolphins
« Reply #5 on: July 27, 2012, 11:14:23 pm »
Unfortunately, I have already drilled the chassis for these LEDs so kind of no turning back.
I am liking this double pole idea.
Excellent!
Actually the panel switch already is.
I am going to have to mod the foot switch, wire, jack.
Thanks a lot!
« Reply #6 on: July 28, 2012, 12:19:55 am »
You may not need double pole switches if you put a filter cap on the rectifier output. As it is, you're unfiltered dc (actually 120Hz pulses) is being connected to the cathodes. It's gonna hum. Very much like a short between heater and cathode.
