September 16, 2026, 11:20:23 pm
Hoffman Amps Forum image Author Topic: power rail question  (Read 4826 times)
Offline ernie_jr
  • gimme a banana
power rail question
« on: August 07, 2012, 02:18:48 pm »
I am looking to build another sunn 200s amp but want to add a second preamp (from an Ampeg B15) On the power rail the last resistor is 33K, if I remember correctly, by adding in another 12ax7 I should make the resistor around 16K to keep the voltages correct. Let me know if I am heading the right way.
Thanks,
Ernie
Offline Iannone
  • If it's too loud, you're too old
Re: power rail question
« Reply #1 on: August 07, 2012, 03:33:34 pm »
That's right.  Ohm's Law - when you double the current (two tubes), you need to cut the resistence in half to maintain the same voltage drop.
Online sluckey
« Reply #2 on: August 07, 2012, 03:49:23 pm »
If you do it like this it will not affect the voltages for the Sunn. All you need to do is pick a value for Rx that gives the voltage needed for the Ampeg.
Offline ernie_jr
  • gimme a banana
« Reply #3 on: August 07, 2012, 08:28:31 pm »
Sluckey,
Thanks taht will work great. The ampeg (if taken off a b26) has about the same voltage as the sunn, so I can just use another 33K
Thanks again,
Ernie
