September 14, 2026, 10:19:56 am
Hoffman Amps Forum image Author Topic: Blues Deluxe Reissue channel switching and reverb help  (Read 4777 times)
Offline goldstache
« on: November 02, 2012, 11:23:51 am »
Hello all, I am looking for some help diagnosing a channel select/reverb problem.  I checked all my Test Points (30-36) and can't seem to understand where my problem lies.
Here are some of the voltages:
TP30
-14v steady
+16v channel change
TP31
nominal voltages
TP32
+16v drive channel selected (supposed to be -16v!!!!)
+16v normal channel (supposed to be +7.5v)
TP33
nominal voltages
TP34
+.082v reverb off
-17.43v reverb on (supposed to be -1.38v)
TP35
+.7v off
-33.1 v on (supposed to be -2.2v!!!!!  Blown Diode????)
TP36
16.35 v off
16.33v on  (supposed to be -15.6v!!!!!)
Also K1 is ticking when I select drive channel and the reverb is on with footswitch plugged in.
With footswitch unplugged.  Only drive channel has reverb.  No reverb on the clean channel at all!
Checked +16v/-16v supply and it checks good.
Checked the 5watt resistors and they appear to be good.
Reflowed all joints on board.
Help!!!!!!!!!!!!!!
thanks
Re: Blues Deluxe Reissue channel switching and reverb help
« Reply #1 on: November 05, 2012, 12:19:06 am »
You are going to have to point to a schematic. The ones I found don't have a TP35 TP36.
Offline goldstache
« Reply #2 on: November 07, 2012, 09:37:02 pm »
Here is an update.  After replace U3, K1, and K2.  I have reverb and channel switching flawless without footswitch.  But with the foot switch, reverb switches good.  But, the drive channel is silent.  And it takes a few seconds for the led on the amp control panel that indicates channel to illuminate or turn off.  It must be a cap having trouble powering up.  So......  I guess I need to try to narrow it down to just the footswitch and associated path to the relay sections of the amp.
Any thoughts?
Thank you.
Offline OldHouseScott
    • Old House Recording Studio
OldHouseScott
"We put a little quality in everything we build..."
« Reply #4 on: November 09, 2012, 12:48:34 am »
Looks like a diode-orgasm in the switching.
Looking at the plan Scott points at:
Check TP33 against the notes lower-left 1st page. Is it going a full + and - 15V, or falling short?
Also TP31 TP32.
Is your "+16V" really 16V?
5W resistors R78 R79 are correctly rated, but I hear on some models they are packed too tight and the solder joints go bad (or the board toasts). Examine.
