September 18, 2026, 09:36:39 pm
Hoffman Amps Forum image Author Topic: Fender HOT ROD De Ville  (Read 6043 times)
Offline Colas LeGrippa
  • MAKE LOVE NOT WAR
« on: January 30, 2013, 11:28:08 am »
Hi,
this amp just came in for repair. The problem is a permanent light squeal on the ''more drive'' channel. I've checked the bias, replaced the 12ax7's, chopsticked and did all what I was trained to with no results. Any idea ?
Thanx
Colas
P.S.: call me Alvin.
Re: Fender HOT ROD De Ville
« Reply #1 on: January 30, 2013, 11:47:52 am »
Colas, you are seeing a lot of amps lately. Have you started a repair business?
  • MAKE LOVE NOT WAR
« Reply #2 on: January 30, 2013, 01:43:49 pm »
Yeah, well for the moment I stay home so all I have to do is play my guitar and fix amps. ( yes my darling and do the dishes  :icon_biggrin: ). I realize that fixing amps especially the PC boards ones is not easy with only a Multi meter and my ears. If I don't go on tour within the next few months, I will try buying a scope. It will keep me busy for a couple of months more, just trying to figure out how it works !
Colas
« Reply #3 on: January 30, 2013, 07:43:24 pm »
Do you have or have you built Dougs listening device? I dont know how i did without it all of my previous years. Dont need to use it a lot but when you get a squeal or crackling going the listening device is the Doctor. No Co Pays either
  • MAKE LOVE NOT WAR
« Reply #4 on: January 30, 2013, 09:06:57 pm »
is it a probe with a 600V cap , the other end being amplified by a small amp ?
stratele52
  • Guest
« Reply #5 on: January 31, 2013, 03:46:39 am »
Hi Colas ,
If these amp use ribbon cables , these cables must be  at the "right " place . Moving them could brig you some noise and probably  squeal  (?)
Try to push or pull them with power ON and heard ....
Good luck
Offline mageerc
  • Is it supposed to smoke like that?
« Reply #6 on: January 31, 2013, 06:58:10 am »
Usually that squeal has something to do with those 470 ohm 5 watt power resistors having a cold solder joint... here's a good link:
http://www.justinholton.com/hotrod/
I realize the text is referring to a Hot Rod Deluxe, but these amps share pretty much the same board...
Randy Magee
Offline Danskman
« Reply #7 on: January 31, 2013, 09:02:31 am »
I fixed a bunch of HRD and Blues DV or DL. Most of their problems are due to bad solders (a lot!), bad tube sockets, bad input jacks (a lot!!).
To gain access to the copper side of the circuit, you have to:
- pull the amp off the cab
- dismount the knobs
- dismount the pots and jacks nuts
- write down the wires connections (CPxx - wire color) on left side of the PCB
- disconnect these wires
- unscrew the PCB
- gently pull the main PCB back
let's go for the debug...
HTH,
Danskman
  • MAKE LOVE NOT WAR
« Reply #8 on: January 31, 2013, 12:08:15 pm »
yeah I know I have redone part of the toasted circuit on a blues deluxe. it takes 45 min to access the pcb board solder side......compare to 5 min on a point to point !
Colas
« Reply #9 on: February 01, 2013, 10:18:50 am »
Yes* It makes the difficult to locate noise problems easy to find.
  • MAKE LOVE NOT WAR
« Reply #10 on: February 01, 2013, 04:51:27 pm »
sure, where woudl I be without it ?
( doin' the dishes in a Mc D ???? )
