September 15, 2026, 01:17:57 am
Hoffman Amps Forum image Author Topic: one channel AB764  (Read 4855 times)
Offline ganzonimx
one channel AB764
« on: February 27, 2013, 01:47:53 pm »
Hello folks
its a long time I last visited this forum and I did a lot of turns in my life, but now I'm back with a amp on my bench. I have to convert a messed up circuit to a one channel AB764. I just want to assure I don't do anything wrong if I connect the 0.1 uf cap from the second stage direct to the PI, dropping out the 220k mixing resistor and the 0.001 cap.
EDITt: I just realized that I have only tree 0.1 caps and I need them for the PI and between the PI and the power tubes. I could take a 0,022 cap from the second stage to the PI I have left over - I think that should also do the job without any major changes to the sound... pleas correct me if I'm wrong...
Thanks Chris
« Last Edit: February 27, 2013, 02:34:24 pm by ganzonimx »
Re: one channel AB764
« Reply #1 on: February 27, 2013, 02:46:41 pm »
Take out the .1µF from the second stage and remove the 220K mixing resistor.
Then connect the plate of the second stage to the .001µF in the PI circuit.
Offline ganzonimx
« Reply #2 on: February 27, 2013, 03:28:04 pm »
Thank you Steve
I thought so...  I see if I find a 0.001, if not,  I'll use a 0.0047 I have laying around ...
Chris
Offline Geezer
« Reply #3 on: February 27, 2013, 04:30:22 pm »
Hello folks
Thanks Chris
Hey Doc, good to hear from you.
I hope those turns were good ones for you.
Welcome back.....
G
Offline ganzonimx
« Reply #4 on: February 27, 2013, 06:05:40 pm »
Hy Geezer!
yea I had a good time and finally I ended up in Tulum on the Caribbean coast... I definitely needed soma climate change   :thumbsup:!
