September 17, 2026, 04:54:49 pm
Hoffman Amps Forum image Author Topic: New project, "Ultimate Studio Preamp"  (Read 8716 times)
Offline nandrewjackson
« on: March 25, 2013, 03:52:24 am »
Hello, I've been a member here for a few years but I don't vistit too often mainly because I haven't been building anything for a couple years.
This new project is due to the fact that I love tinkering with JCM/<MESA RECTO/ Soldano type high gain preamps, but I have really gotten sick of changing components out to get new sounds.  Hopefully **** I can pull this off without too much noise due to the amount of wiring/pots in the signal chain.
All of the pots/switches are basically the most things I tinker with in my homemade preamp (originally the Hoffman Preamp with an extra stage).
here are my first two chicken scratches on paper, I have yet to start the actual build.
Let me know if you have any thoughts about this project.
Thanks. Noah.
Re: New project, "Ultimate Studio Preamp"
« Reply #1 on: March 25, 2013, 07:38:34 am »
I would put a resistor in series with each cathode pot (maybe 500Ω) just to prevent dialing in zero ohms. Zero ohms will result in zero volts bias and the tube will go into heavy conduction.
« Reply #2 on: March 25, 2013, 11:41:45 am »
Also a large resistor in parallel with the boost switch as to avoid pop
or you can use the arrangement you can see under V2a here
as you want to use all those pots may be it will be more safe to use this architecture using non conductive bars
or, at least a small piece of non conductive material in the middle, this will avoid electro shock and the use of long wires that can cause other problems
« Last Edit: March 25, 2013, 11:49:53 am by kagliostro »
« Reply #3 on: March 25, 2013, 11:58:19 am »
Thanks for that sluckey,,,,obvious, but easily omitted
« Reply #4 on: March 25, 2013, 07:42:36 pm »
The tubes with 150K plate resistors won't get hurt.
They may sound awful, and the 150K may smoke if not big enuff. But zero-bias on a tube with large plate resistor is not death-to-tubes.
(POWER stages with negligible dead resistance will, of course, melt quickly.)
« Reply #5 on: March 25, 2013, 08:47:46 pm »
yeah, sluckey, I thought about putting some sort of safety resistor under the cathode pot to prevent a zero situation, I just didn't think of it before I drew the circuit out.
I really didn't consider the "pop" with the cathode switch, kagliostro, but I will definitely keep that in mind.  And I also like the idea of extending the pot control like that.  I've been considering how close the board needs to be to the control panel, but your idea might make things a lot easier!
Thanks for all the input.
Noah
« Reply #6 on: March 26, 2013, 03:36:52 am »
Nowadays you can see those long shaft pots used by some HiFi guy
in the past the use of long shaft was common in Radio Frequency equipment
Offline jazbo8
« Reply #7 on: March 26, 2013, 06:32:38 pm »
Can 1/4" jacks be used for the output since it has pretty large voltage swing on it? What's the rating for them anyway?
Jaz
Q
« Reply #8 on: March 26, 2013, 07:52:48 pm »
the output will be 1/4". With the cathode follower, then the EQ, then another cap to isolate DC and a 1M volume pot, it would be fine to run it right into anything 1/4"    (mixing console, power amp, etc.)
Offline Bluemeany
« Reply #9 on: March 27, 2013, 12:57:56 pm »
What amp is this schematic for? I like the look of it!
« Reply #10 on: March 30, 2013, 07:22:54 pm »
That was only one of the idea I had about the conversion of a modulator for Radio Frequency Transmitter in guitar amp
http://www.el34world.com/Forum/index.php?topic=10392.0
The one I posted is my preferred, the other two, as I see things now, requires a Source Follower (IRF820 Mosfet used as CF) between the ef86 tube and the Tone Control
« Reply #11 on: April 10, 2013, 01:36:12 am »
here is the circuit board and the front panel.  It is 3U rackspace.
circuit board is done, the frontpanel is not even close to done.  17 knobs and 6 switches for a single channel preamp.  Wow, can anyone say "overdone". lol
I've decided I"m going to add a "fender" EQ inbetween the first and second stages, and have it switchable "in" or "out".
« Reply #12 on: April 10, 2013, 02:02:40 am »
Why do you want to limit you to a Fender Style TS, you can plan to build a switchable small multi purpose board as to try very different circuits (FMV - Baxandall - James - BoneRay - Tilt Coltrol - Raw Control ...............)  :icon_biggrin: :icon_biggrin:
Using this pots
http://it.rs-online.com/web/p/potenziometri/0393841/
you can stack it in parallel as to have a "multi Layer" pot so in one shaft you can have 2 pots (or more) of different value to be used for different TS configuration without have a forest of knobs
It will be interesting also to be able to shift the TS from one gain stage to one other  :icon_biggrin:
« Last Edit: April 10, 2013, 02:42:29 am by kagliostro »
« Reply #13 on: April 10, 2013, 04:13:59 am »
 :icon_biggrin:
the "mad scientist" bug is alive in this project.
I only want the fender ts between stage one and two for the deep mid scoop capabilities, and fender ts and marshall ts at the output because they are most popular.
I'm thinking of making a bass pre for my bass player friend. maybe in pedal form.  I will probably usemore exotic eq's in that project.  and it will have way less stages lol.
« Reply #14 on: April 10, 2013, 05:34:45 am »
« Reply #15 on: April 10, 2013, 02:51:49 pm »
thanks for the links, kagliostro, those look like good projects.
I've been studying bass specific schematics trying to see what the major differences are between them and guitar circuits.
I'm beginning to  think bass players are more picky than guitar players! :l2:
