September 15, 2026, 11:11:43 am
Hoffman Amps Forum image Author Topic: There is a tube with 1/2 12ax7 + ef86 in the same envelope ?  (Read 9058 times)
Few time ago this question was posted on an australian forum
I would like to here also the opinion of the members of el34world
about the existence of a tube that contains in the same envelope 1/2 12ax7 + an ef86
http://www.nj7p.info/Common/Tube/SQL/Tube_query.php?Type=12AX7
http://www.nj7p.info/Common/Tube/SQL/Tube_query.php?Type=6CF8
The tubes that were proposed are 6an8 and 6jn8
http://www.nj7p.info/Common/Tube/SQL/Tube_query.php?Type=6AN8
http://www.nj7p.info/Common/Tube/SQL/Tube_query.php?Type=6JN8
What about an what about other candidates ?
« Last Edit: April 20, 2013, 11:20:53 am by kagliostro »
Re: There is a tube with 1/2 12ax7 + ef86 in the same envelope ?
« Reply #1 on: April 20, 2013, 12:51:14 pm »
Sunn used the 6AN8 in many of their tube amps. The triode was the PI and the pentode was a voltage amp just prior to the PI. They also used a 7199 in the exact same circuit for some other amps. Pin out is different for the tubes.
Ampeg also used the 7199  as the PI in the Gemini series amps, maybe others too.
I don't know how either 7199 or 6AN8 may compare to 12AX7 or EF86. Probably worth experimenting. I've never actually seen either 7199 or 6AN8 used in a preamp circuit, but the RCA Receiving Tube manuals (for sure RC-23) show a 7199 in a phono ceramic cartridge pickup and also as a PI in several hi-fi power amps. You can find the RCA manuals online if you don't have a paper copy.
« Reply #2 on: April 20, 2013, 01:37:12 pm »
Hi K, I can't comment on how close these tubes are to an EF86 but it seems that Gar (Garnet Amps) liked these tubes in his amps http://www.el34world.com/Forum/index.php?topic=13990.0
He also liked the 6JW8.  :icon_biggrin:
« Reply #3 on: April 20, 2013, 07:37:44 pm »
Thanks Sluckey & TIMBO
I've also seen the ecf80 (6bl8) tube but I'm not able to evaluate it
http://www.nj7p.info/Common/Tube/SQL/Tube_query.php?Type=6BL8
« Last Edit: April 20, 2013, 07:49:09 pm by kagliostro »
« Reply #4 on: April 20, 2013, 08:40:22 pm »
The tri-side of most pent-triodes is 12AU7 like, not 12AX7 like.
That much gain in one small inch would be dangerous.
« Reply #5 on: April 21, 2013, 02:36:25 am »
Actually, even if I'm not so expert to understand completely the datasheet
I can see that those tubes (6an8 - ecf80 - 6jn8) are indicated as Medium-Mu Triode - Sharp-Cutoff Pentode
and 12ax7 is a High-MU Triode
searching I've find this
6as11 - 6bd11 - 6m11 are High-Mu Twin Triode - Sharp-Cutoff Pentode
http://www.nj7p.info/Common/Tube/SQL/Tube_query.php?Type=6AS11
http://www.nj7p.info/Common/Tube/SQL/Tube_query.php?Type=6BD11
http://www.nj7p.info/Common/Tube/SQL/Tube_query.php?Type=6M11
but I'm not sure the pentode section of this tubes is comparable to an ef86 tube
there is also one other interesting tube
6mf8 High-Mu Triode - Beam Power Tube
http://www.nj7p.info/Common/Tube/SQL/Tube_query.php?Type=6MF8
I've only seen schematics where the pentode of a 6af11 Twin Triode - Sharp-Cutoff Pentode
was used as power tube in a small amp
http://www.nj7p.info/Common/Tube/SQL/Tube_query.php?Type=6AF11
not as preamp tube, and also if I know that someone has used el84 as preamp tube I can't say if between the pentodes on this compactrons and the ef86 there is a large or small difference
« Last Edit: April 21, 2013, 03:08:45 am by kagliostro »
« Reply #6 on: April 21, 2013, 11:02:45 am »
there is also one other interesting tube  6mf8 High-Mu Triode - Beam Power Tube
i have a few of those. looks like they are built similar to 1/2 of 12AT7 and a 6HE5 in same envelope. 6MF8 is also similar to the 6LU8. i have a small stash of both and are in my amp cookbook.
on another footnote: the 6DT6A looks promising as 5879 sub in a 6AU6 like equipped ckts. (actually, g3 and k are swapped but usually for audio that's moot).
« Reply #7 on: April 21, 2013, 02:28:39 pm »
Thanks for the info Pete
