September 15, 2026, 04:41:54 pm
Hoffman Amps Forum image Author Topic: relay switching  (Read 5101 times)
Offline Colas LeGrippa
  • MAKE LOVE NOT WAR
relay switching
« on: April 21, 2013, 12:48:18 pm »
Hi, I have never installed a relay in my life. I need a spst relay for switching on/off  a 12ax7 cathode cap and resistor. Voltages avilable in my amp are: 6.3v, 117v, HV and -45v.
what is the best way to do it to avoid any noise? I need approx 25feet of cable between the footswitch and the amp. I know very little about amplifiers relays.
Thanks !
Colas
P.S.: call me Alvin.
Re: relay switching
« Reply #1 on: April 21, 2013, 02:12:19 pm »
I have to pull your ears Colas  :l2: :l2:
why you don't use the search function of the forum  :icon_biggrin:
http://www.el34world.com/projects/relay_switch.htm
Ciao
Re: relay switching
« Reply #2 on: April 21, 2013, 03:09:11 pm »
32 posts with photos, info,schematics,layouts .....................
ARCHIVES
http://www.el34world.com/Forum/index.php?topic=14348.0
Re: relay switching
« Reply #3 on: April 21, 2013, 03:26:38 pm »
He's too busy kissing his wife!  :laugh:
« Last Edit: April 21, 2013, 03:43:32 pm by John »
  • MAKE LOVE NOT WAR
Re: relay switching
« Reply #4 on: April 21, 2013, 04:35:29 pm »
there is a search function ???????????
never seen that.
I moved one step further, John !
ok now, If I can't rely on people but on a search button, where is the world goin' ?
thanks anyway, I'll try to talk to some kinda function and find out what I'm looking for..I thought a forum was people.......[/b][/color]
Cocaïne Colas
Re: relay switching
« Reply #5 on: April 21, 2013, 06:13:59 pm »
I use the search feature frequently.  Everytime I do, I am very very grateful that someone has been kind enough to share information so readily to this amp building community.
Take the relay section in the ARCHIVES ................. there was a handful of us that worked collaboratively to compile that info in one place for others to benefit from.  It tooks a number of weeks and ALOT of editing. I think it's very cool that it exists and is easily available. Kind of an walk thru the process tutorial really.  Hoffman, Sluckey, Geezer and many others helped put that together for us.
Re: relay switching
« Reply #6 on: April 21, 2013, 08:33:41 pm »
> relay for switching on/off  a 12ax7 cathode cap and resistor. ...approx 25feet of cable
You can probably run 25 feet of cable from a cathode without real problem. Clip or tack it together and try it. Unless your electrical environment is VERY ugly, it may not even have to be shielded cable. (I've run 440 ohm microphone lines 100+ feet past an elevator in cheap speaker wire.)
Re: relay switching
« Reply #7 on: April 22, 2013, 06:38:26 am »
Ciao Colas
If you give a try to the "SEARCH" option that is between "HELP" and "PROFILE" (on the left of the screen) you will find an advanced Search Engine
I use often that function with satisfaction
you must consider that there you can find also more treads dedicated in some way to the argument you are looking for
and the more you can read about a thing the more is possible you find something of your interest :grin:
  • MAKE LOVE NOT WAR
Re: relay switching
« Reply #8 on: April 22, 2013, 07:07:08 am »
PRR, this is way more simple than with a relay !
Thanks for the tip.
Franco, I know the search engine, I was joking :icon_biggrin:
Good day to all
Colas
Re: relay switching
« Reply #9 on: April 22, 2013, 01:05:47 pm »
You know, I think I've discovered the advanced search engine after one year I was in the forum
before I used only the Search disposable at the right upper side   :l2: :l2:
