September 18, 2026, 02:24:41 pm
Hoffman Amps Forum image Author Topic: Found an Old Mono Hoffman Record Player with 5E3 configuration  (Read 36366 times)
Offline Platefire
The Devinator is Here!
« Reply #100 on: January 23, 2014, 12:44:05 pm »
Here is the finished pictures. I just need to build a speaker connection cord with 1/4 to 1/4 male plugs and also one with 1/4 to speaker connectors/clips so he can hook it up to any speaker situation. Platefire
On the right track now<><
Re: Found an Old Mono Hoffman Record Player with 5E3 configuration
« Reply #101 on: January 26, 2014, 08:22:15 am »
Plate, nice work.  What do you think of the Master?  Does it work without messing with the natural interaction between the 2 volume pots?  Will it silence the amp completely?
Offline Platefire
« Reply #102 on: January 26, 2014, 11:48:15 pm »
Thanks Ed
There is no interaction because it's only a one channel amp. I used the other gain stage that the other channel would use for a hot switch.
I played it this weekend in my church band using my Aria 335 copy. I had to play around with the vol settings but I got what I wanted with the master at about 11:00 oclock, tone about 12:00 oclock and pre vol about 10:00 oclock as I recall. I'm happy with the MV and as I recall will completely silence the amp at "0" but on the other hand I haven't actually tested that, so I would have to double check to be sure.
The amp is really quiet regarding operational noise, so that's a plus. I really got chewed out today when my wife learned I was planning on giving this to my grandson without a cover over the tubes. She said he will smash the tubes! She may be right? Platefire
