September 18, 2026, 03:12:18 pm
Hoffman Amps Forum image Author Topic: foot controlable speed and intensity?  (Read 4713 times)
Offline Sandoz6G16
« on: August 28, 2013, 08:17:35 pm »
Has anyone tried to put speed and intensity on organ volume pedals or wah pedals before it seems like it would be easy to use a stereo jack and wire up a pedal and would be a nice feature
Offline phsyconoodler
Re: foot controlable speed and intensity?
« Reply #1 on: August 29, 2013, 04:00:12 pm »
go for it!
Offline super&plexi
  • Love 2 gig for bread...Love 2 play/jam for free
« Reply #2 on: August 31, 2013, 11:11:51 pm »
got a speed control for my boss spinny speaker thing. 1meg pot in a wah shell. wiper(center), & outer leg(either). if it goes "wrong way'' (slow down,  fast up},  or vice versa, but you want other direction, just change outer wire to other side; 1, or 3.   2 is middle. assuming you have jack for speed.  super easy, and fun for ramp up, ramp down make the drunk dancers dizzy effects/affects!
keep on with those scales and that fish is gonna die, if it don't bite you first!
never fried a tranny ..till I built a dim bulb tester. UPDATE-haven't fried anything since learning how to properly build & use one...thanks Uncle Doug, & el34 World
« Reply #3 on: September 01, 2013, 04:54:45 pm »
You could have a simple 'stepped' tremolo speed control with a dual foot switch that parallels a couple of resistors in the RC feedback network in the LFO stage. The resistors themselves would be in the amp, and you could then get away with just an ordinary passive foot switch (like the way its done in a 1960 AC30)
While I could think of handy uses for occasionally changing the trem speed on the fly, I usually wouldn't change the intensity in mid-song in most gigs. I just fiddle with the depth knob between tunes.
« Last Edit: September 01, 2013, 08:55:56 pm by tubeswell »
Offline terminalgs
« Reply #4 on: September 01, 2013, 08:01:18 pm »
Univibe  did it (Jimi,Pink Floyd..).  It used a dual pot (100K log,  maybe one was reversed from the other?).  One controlled the speed of the oscillator, the other controlled tone (??)
It would be easy to use a switched jack that would override manual amp-located pot speed.   The intensity might be a trick, depending on the circuit you are trying to adapt it to.
for example: If adapting, say a tremolux,  you'd have to run 3 wires to the pedal-pot just for intensity.  with a TRS stereo jack, you've got three wires that you can send to a remote pedal.  If you use a switched jack, you can have pots in the amp the pedal overrides.  For speed, its easy:  1 mono switch jack. For intensity, you'd need to use another TRS switch jack (no ground in that one).  So, it could be done with 2 TRS 1/4 jacks.
If you don't care about having override-able pots in the main chassis, and you are content to say the amp doesn't function without the pedal, you could use a DIN-5 or something like that.. (non-switched...)
are you envisioning two footpedals,?  One for speed , one for intensity?
Offline super&plexi
« Reply #5 on: September 02, 2013, 04:57:09 am »
  I like to change speed all the time, fast slow, like a B3 player ramping a Leslie up & down. sounds great, to accent movement from verse to chorus, or any change in a songs form
