September 18, 2026, 02:08:26 pm
Hoffman Amps Forum image Author Topic: Sovtek Mig 100 Plate voltage?  (Read 6708 times)
Offline Leevi
    • Rikstone
stratele52
  • Guest
Re: Sovtek Mig 100 Plate voltage?
« Reply #1 on: September 01, 2013, 03:37:39 pm »
You want to built one ? Or help a friend by mail ?
Nothing on Schematic ;  http://www.blueguitar.org/new/schem/sovtek/mig-100h.gif
But with two 300 volts filter caps in series ( good for 600 V with no safety margin ) I said between 400 and 500 / 550 v.
« Reply #2 on: September 01, 2013, 04:31:43 pm »
Last time I was inside my friend's Mig 50 it was 537vdc on 2 x 5881  :huh:
pretty standard stuff on those amps to be that high...
Offline SoundmasterG
« Reply #3 on: September 01, 2013, 10:58:10 pm »
The early MIG 100U that I gutted and built into a Vox AC100 clone is about 480V or so. I kept the Sovtek power transformer but used a Heyboer OT. I still have the Sovtek OT and choke, and stuffed circuit board around here too if anyone is interested in them. If so send me a pm.
The specs on the 5881 were with the old standards....they changed to a new way of measuring and all the specs on all tubes went up a bit when they did that. New Sovtek 5881's can take just as much voltage or more than any 6L6GC today. They are very sturdy tubes! Not sure about the Tung Sol reissues, but I would expect they are probably the same as modern 6L6GC's for their specs.
Greg
Offline Leevi
    • Rikstone
« Reply #4 on: September 01, 2013, 11:53:22 pm »
Thanks for the replies. Another thing I wonder is the wiring of the power amp.
There is a PT with CT but they use still a bridge rectifier? And furthermore the CT
is connected to the point between two filter caps. What might be the reason for this?
/Leevi
« Reply #5 on: September 02, 2013, 12:29:03 am »
> a PT with CT but they use still a bridge rectifier ...  the CT is connected to the point between two filter caps.
That point is half-voltage.
If you ground the CT, you get the + and - supplies often used for audio op-amps.
If you ground the bottom you get +300V and +600V, suitable for large 6550/8417/KT88 amps with higher load impedances.
Here it is a convenient way to be SURE the stacked filter-caps take the voltage equally.
Offline Leevi
    • Rikstone
« Reply #6 on: September 02, 2013, 02:50:35 am »
So how much will be the voltage after rectifier in this case, let's say we have
PT with 250-0-250 secondary, 700v or 350v?
/Leevi
« Reply #7 on: September 02, 2013, 08:20:16 am »
700v unloaded
