September 17, 2026, 08:30:53 pm
Hoffman Amps Forum image Author Topic: Non-marring socket drivers?  (Read 5279 times)
Offline spacelabstudio
  • Unable to leave well enough alone
« on: December 29, 2013, 05:52:02 pm »
So, my wife got me a pretty nifty electric screwdriver for Christmas.  I'd like to be able to use it to mount pots and other panel mount items with hex nuts.  Getting hold of sockets that are long enough doesn't seem to be a problem, but I'd like to protect the finish.  Does anybody make non-marring versions, with like a rubber tip or insert or something?  What do you guys use?  Buy some silicone, dip some sockets in it, and let it cure?    (Hard to get inside dimensions right, there.)
Chris
stratele52
  • Guest
Re: Non-marring socket drivers?
« Reply #1 on: January 03, 2014, 03:02:44 pm »
IMO good quality socket won't scratch nut or panel . I use those at home
Online sluckey
« Reply #2 on: January 08, 2014, 11:31:16 am »
A piece of masking tape across the open end of the socket works very well for me. I just use a ≈2" piece of 3/4" wide tape. Center it on the end of the socket and fold up along the sides of the socket to hold in place. Then use a utility knife to cut out the hex profile. It took longer to write this than it takes to do it.
Using a flat washer under the nut usually prevents any marring if you are careful. Also, using 6 point sockets rather than 12 point sockets will prevent a lot of accidents caused by socket slippage.
« Last Edit: January 08, 2014, 11:34:38 am by sluckey »
