September 14, 2026, 06:47:42 pm
Hoffman Amps Forum image Author Topic: motorboating tremolo  (Read 4882 times)
Offline Leevi
    • Rikstone
« on: January 31, 2014, 02:51:30 pm »
I succeeded to get the tremolo ticking in my last project.
It's ticking even if the volume is off.
Do you have any tips how to eliminate that?
/Leevi
Offline phsyconoodler
Re: motorboating tremolo
« Reply #1 on: January 31, 2014, 06:34:07 pm »
Single ended with an EL84 and a 6V6? Clever!
  It's all about lead dress in your tremolo circuit.Moving wires around and also shortening wires to grids to start with.
Offline Leevi
    • Rikstone
« Reply #2 on: February 02, 2014, 07:01:04 am »
I tried many changes, I even changed the structure of the
tremolo circuit without result. Then I moved the tremolo to the cathode
of the first amplification stage which helped. I would say it works much better
there. Also a noise problem when turning tremolo depth disappeared
and no ticking at all.
/Leevi
« Last Edit: February 02, 2014, 10:18:33 am by Leevi »
stratele52
  • Guest
« Reply #3 on: February 02, 2014, 08:34:52 am »
A 0.022 cap connected to the neon lamp may stop it
« Reply #4 on: February 02, 2014, 08:45:13 am »
Where do you see a neon lamp???
