September 08, 2026, 07:53:16 am
Hoffman Amps Forum image Author Topic: *umbolt lite done.  (Read 81225 times)
Offline phsyconoodler
*umbolt lite done.
« on: October 18, 2007, 01:31:37 am »
I finished my 'overdrive rocket today,and it sounds marvelous! It has a sweet clean tone and a thundering overdrive.I have 6V6's in this one with Hammond Transformers.sounds likea *umble should.Cleans have tones of headroom and the overdrive is from mild to over-the-top insane.Sustains for days.
  I'm really happy with this one!
Re: *umbolt lite done.
« Reply #1 on: October 18, 2007, 01:35:08 am »
Another shot.
Offline Wanabejimi
« Reply #2 on: October 18, 2007, 09:23:38 am »
I've built two...one lite and one full blown umblot with all the relays and bells and whistles.  They are great amps and the lite is, hands down, my main amp now.  I can walk into a gig carrying all my gear in both hands.  I run a little delay through the effects loop.  I keep the overdrive channel on and I don't touch the amp again.  I just use the volume on my guitar.   Nice looking build too!!
« Reply #3 on: October 18, 2007, 10:27:33 am »
The channel switching is done with mini switches right now,but I want to put relays in there to make it foot switchable.This chassis is a small one I had laying around but the relays are relatively small so I'll see if I can cram them in there.The board is a glass/epoxy one with hole drilled in it.This circuit really is brilliant,I can see why people like it.The cleans are quite impressive,but they don't excell for rythym work.The notes jump out at you when you dig in though.It doesn't distort on the clean channel until you pin it and the overdrive is very pleasant sounding.If you play lightly it seems to be muted a little.It needs to be played a bit aggressively to make it really shine,but it does indeed shine when pummeled.The orange drops are mallory and they seem to be a mate to this amp.
  Now off to make a head box.....
« Last Edit: October 18, 2007, 10:37:06 am by phsyconoodler »
« Reply #4 on: October 18, 2007, 12:32:49 pm »
Sorry bluez!She's married!
« Reply #5 on: October 19, 2007, 12:15:15 am »
Go to www.brownnote.net .The layout and schematic are there.
« Last Edit: October 19, 2007, 12:16:51 am by phsyconoodler »
Offline Geezer
« Reply #6 on: October 19, 2007, 09:43:11 am »
It took some looking, but I found one in their forum>>>
http://www.brownnote.net/forum/viewtopic.php?t=274
Offline drew
« Reply #7 on: October 19, 2007, 11:08:03 pm »
Which particular Hammond transformers did you end up using?
« Reply #8 on: October 19, 2007, 11:43:07 pm »
I used a 272HX and a 1650H.
Here's a shot of it in it's headbox.Excuse my lousy photography.
« Reply #9 on: October 22, 2007, 09:17:52 pm »
Black goop on a clone?
  I really need a new camera or a lesson in photography!Here's the last shot.
Offline 12bz7
« Reply #10 on: October 23, 2007, 09:03:55 am »
Here's one I prepared earlier. ;D
It's as small as I could go with a 12" speaker 17" x 15.5" x 9".
Added a switchable Fender clean channel, called it the vintage channel and the Dumb side modern channel ( because I lack imagination and originality).
I used relays for channel, preamp boost, overdrive. It does 'pop' switching between fender and dumb so will have to sort it out .
Offline 12bz7
« Reply #11 on: October 24, 2007, 10:49:23 am »
That is one great looking combo!
  I built my own chassis and it's considerably smaller that the D'Lite chassis,consequently I can't fit the channel switching relays inside the chassis.I'm putting them outside the chassis.I originally planned on a 2-10 combo but I wanted to hear the amp before I built the cabinet,so I stuffed it into this head I threw together one morning.I'm overwhelmed by the tone of this circuit!
  A friend came and tried it out and made me an offer I couldn't refuse,so it's sold.I'm building another now and won't have any reservations about building a combo.But the speakers will be paramount I think.It sounds lovely with greenbacks,but maybe a G12H-30 would be better,or a couple of Eminence 10's.
Thanks for your kind words phsyconoodler but yours is a much nicer build. I too
made a chassis from an offcut of alu' I had laying around. Used a hammer and  4x2 block off wood , so it's very rough. Much easier to buy one from mr hoffman imho. This whole build came about to use up leftover parts and make an amp that was small and light.
Your idea of putting relays on the outside of the chassis may be the cure I'm looking for. I think this amp has high freq' osso or crosstalk between clean channels. I turn either volume or treble knob on each channel past 12o'clock and it squeels like a cut pig. Hence all the shielded wire( which will come out eventually as soon as I can cure it). With the relays on the outside it might make for better leaddress ( I've never had or heard hi freq' osso before). I'm also thinking the unused channel may have to be grounded when switched out, I don't know but it's a learning experience. I think the best speaker for a D amp is the EV. I have a couple which I'm saving for future builds ( I can't afford them really), I AB'd them against many other speakers and for this type of build  there is no equal.  I guess that's why he used them.
Offline 12bz7
« Reply #12 on: October 24, 2007, 11:46:56 am »
Any features on the amp that did NOT impress you as a "must have" feature like the PAB
(pre-amp boost) or treble boost or .............. ?
Could anything else be removed to go from Lite to Ultra (Lite)?
For example I found I don't change presence knobs much so my last build, .... I just used a resistor and cap and lost the pot.
Anything beside have it relay switchable that you'd do different?
Hi Tubenit.
On my build I ditched all the preamp switching. Bright, mid boost, jazz/rock, deep, LNF ect. as I never use it ,interesting in it's day I think but now days I think guitarist want it at hand ( built in guitar). There's so much diversity in guitar manufacture and add on parts, pickups ect today. If you took the time you could simplify it down to what's really needed for good tone and ease of use. Like you say  about about the presence pot , not needed if you don't use it. I did a recap on a mid '60s bassman head for a customer last week, had to change a couple of noisy 1watt 100k CC plate resistors as well (used allan bradleys). Plugged it in to a  box with a 12" eminence speaker and played a cheap asian strat copy. I was gobsmacked with the sound. It felt great,played great, sounded great. Now I want one. Leo was a genius.
« Reply #13 on: October 24, 2007, 12:07:15 pm »
Yeah i agree.Leo was a genius.I really love bassman heads like the AA864.Killer!
   This *umble lite however is really brilliant too.I don't use the mid-boost in this amp but have the OD and preamp boost which just lifts the tone stack.It is useful for some music.The overdrive is thick and surupy and sustains for days.It does a good classic JCM800 rock tone without the brashness the marshall gives.Lead dress is important for quiet operation but I only have one shielded cable to the input.Mine is relatively quiet.
Offline Dynaflow
  • Have a cow man!
« Reply #14 on: October 25, 2007, 08:39:48 pm »
 What brand caps are the blue ones on the left (I'm assuming filter caps)?
Regards,
Dyna
Offline drew
« Reply #15 on: November 11, 2007, 05:13:06 pm »
These amps look good in red . . .
Offline punkykatt
« Reply #16 on: November 11, 2007, 07:29:00 pm »
Hey Drew,  Are those two red boxes behind the preamp switches the switching relays?  It would be great if you can post a picture of that area .  Thanks Punky
« Reply #17 on: November 11, 2007, 08:52:06 pm »
Those are the switching relays.There are real clear pictures on the Brownnote site.
  I just finished my relay and power supply boards and I'll post a pic when they are installed.Mine will be in different locations than the brown note build and I used 6.3v for the relays with a regulator.
Offline drew
« Reply #18 on: November 11, 2007, 10:15:15 pm »
Here's a shot of the relays.
I made the relay board months ago.  Since then, guys have been going to triple-relay systems (bright, OD, PAB with a three-button footswitch, or a two button footswitch controlling PAB and linked OD and bright), and PCB's have been made available.  If I had it to do over again, I would have gone that route.
Offline punkykatt
« Reply #19 on: November 12, 2007, 10:16:11 am »
Thanks for that info Drew.
Offline ampgeek
  • Viva La Tube!!
« Reply #20 on: November 12, 2007, 03:10:50 pm »
Psycho,
Another VERY nice looking build there.  Likewise for the other D'Lite examples in this thread!
I notice that you didn't go the MF plate resistor route on yours.  Many of the folks building these believe that they are a part of the required "magic" for the D tone.  Any thoughts/comments/experience that you could share on that topic?
I threw mine together and stuffed it into a Bogen enclosure many months ago and have been tweaking/experimenting with all of the various mods and changes being discussed ever since.  Finally ended up with the Bluesmaster/Dogears mods and am extremely satisfied with the results.  Currently using a 1X12 Avatar oval back loaded with a G1265.
Somewhat outdated thread here:
http://www.brownnote.net/forum/viewtopic.php?t=382
I have since cleaned it up quite a bit.
Played my first gig with it this Saturday (Blues/Classic rock covers) and was very pleased with it's performance!  Very full, round and 3D'ish tone.  Liquidy, "sustain for days" OD tone to die for.
A couple of strangers (and fellow guitar playing bretheren) were, well....dumb-founded.....by the fact that I was using only a single amp and a single 1X12 cab.  They were convinced that I had a microphone hidden somewhere in the cab and was piping it out to the PA mains!
I am not sure that the purists would give it the thumbs up for nailing the D'tone.  But, it certainly is a unique sounding and enjoyable to build and play plan.
Dave O.
Offline ampgeek
  • Viva La Tube!!
« Reply #21 on: November 12, 2007, 04:58:11 pm »
Sorry about that!
There was a lot of discussion on the use of metal film resistors on V1 and V2 plates at the BrownNote and AmpGarage forums back at the beginning of the year when the D'lite plan "hit the street".  IIRC, the Vishay Dale RN65D seemed the gold standard for this application.  Most of the experienced D'guys felt that they were an important part of the puzzle.
I am not smart/experienced enough to be skeptical so I just followed suit.
Just wondering if you had a strong opinion one way or the other about their use.
Thanks much,
Dave O.
Offline drew
« Reply #22 on: November 12, 2007, 06:42:09 pm »
These . . .
« Reply #23 on: November 13, 2007, 01:51:58 am »
I'll have to read that thread.I can't possibly imagine what difference the 'type' of resistors have to do with anything here????
Offline ampgeek
  • Viva La Tube!!
« Reply #24 on: November 13, 2007, 12:22:16 pm »
Phsyco,
Like I said, I am not smart/experienced enough to provide any useful info/data on this topic.
However, I know that MF use was discussed/debated/"tested"/etc frequently on a couple of the other forums.
Here is just one example over at the AmpGarage forum:
http://ampgarage.com/forum/viewtopic.php?t=2884
I don't think that this excercise was totally conclusive though.
My understanding is that HAD utilized MF's exclusively(?) in certain locations/applications.  Hence, their use became one of those pieces of the tonal puzzle that should be reproduced when trying to obtain that D tone (whatever "that" is!).
It is my understanding that every D is a little different and, as we all know, an amp's tone is to a certain extent due to the interactions of the various components.  So it is nearly impossible to point to a single component and say "this is why it sounds like that".  That would be way to simple.
Anyway, when the hobbyists like me see the respected experts like you leaning in a direction believed to be different than the "herd", it becomes worthy of a question or two.  Call it looking for enlightenment!  I was just wondering if you had contemplated this topic.
Thanks much,
Dave O.
Offline jgriffes
« Reply #25 on: November 28, 2007, 09:37:36 pm »
hey phsyco, I am building one of the umbolt also, and was wondering on the hammond tranny there is no bias feed.  I was wondering if you used the same bias setup and resistor values as the schematic bias becuase i am gonna have to feed the bias off of the 300v secondary.  any help would be great.  thanks, Jgriffes
« Reply #26 on: November 28, 2007, 10:35:48 pm »
If you look back at the pictures you'll see a little board above the main filter cap board.That's where the bias supply boartd is.It is identical to a Marshall 2203/4.I just had to alter the range resistor to get the bias in the right range for the 6V6's.
Offline jgriffes
« Reply #27 on: November 28, 2007, 11:16:05 pm »
thanks aton, I figured thats what you did but it's kinda hard to see from the pictures.  What value did you end up using for range resistor?  (I plan on using 6v6's as well, I haven't built one with them in yet so I figured I'd give them a shot.)  Thanks again.
« Reply #28 on: November 29, 2007, 11:11:22 am »
It depends on the PT you are using.I think I ended up with a 65k range resistor,but yours may be different.I can bias for any octal tube now.KT77's are particularly tasty sounding,but 6v6's are the best for my particular transformers.
Offline drew
« Reply #29 on: December 04, 2007, 09:33:25 pm »
I've just noticed that I somehow ended up using a 1/4 watt, Vishay Dale RN65C (instead of the 1/2 watt D) 121K resistor on V2.   :(  Is this a high-priority item to change out?
« Reply #30 on: December 04, 2007, 09:37:54 pm »
there is no 121k resistor on V2.If you are referring to the 120k plate resistor,it has to be at least 1/2 watt or 1 watt would be best for plate resistors.
« Reply #31 on: December 04, 2007, 09:53:38 pm »
Here's a shot of my latest Overdrive rocket with reverb underway.
Offline drew
« Reply #32 on: December 04, 2007, 10:28:07 pm »
For whatever reason, those Vishay Dale resistors don't come in 120K, 180K, or 220K, so you end up using 121K, 182K, and 221K.  (But there is a 150K.)  http://www.mouser.com/catalog/632/545.pdf
From this data sheet http://www.vishay.com/docs/31027/cmfmil.pdf , specifically the table on the lower part of page 3, it looks like the RN65C is rated at 1/4 watt at 125 degrees C, and at 1/2 watt at 70 degrees.   :-?
I'll see what the Dumble gurus on ampgarage.com think.
« Reply #33 on: December 04, 2007, 11:58:24 pm »
Well it sounds like you answered your own question.Your amp can easily get to 70 deg.C. inside so that resistor is not good enough.
« Last Edit: December 05, 2007, 01:32:05 am by phsyconoodler »
Offline jgriffes
« Reply #34 on: December 05, 2007, 07:24:57 pm »
your builds look great!  Where do you get your face plates?  and also for the relays, I am using 5v relays.  Do these call for 12v relays?
« Reply #35 on: December 05, 2007, 07:26:52 pm »
I make my own faceplates now.I have the use of a laser engraver.I use Omron 5v relays.About 35ma current draw.
Offline markmalin
  • Malin Sweet Loraine
    • Malin Amplification
« Reply #36 on: December 08, 2007, 06:42:10 am »
Do you recommend not shielding the Volume, Master Volume and Overdrive connections like the D'Lite layout then?
Mark.
"... there are Flying V's and then there are the ones shaped like peanuts..."  - my son at age 9
« Reply #37 on: December 09, 2007, 12:39:08 am »
Not every build will be quiet.I would shield the input to grid,the overdrive and overdrive level.The original dumble didn't shield the master.There is no need to shield the volume control.
D'Lite Reverb Draft ?
« Reply #38 on: December 09, 2007, 09:19:42 am »
Looking at how others reportedly have had success with adding a one tube reverb .......... I drew this up.
Any comments or observations?
Reportedly, only a small amount of reverb is used with these amps which makes sense to me.
I don't have any plans to build this amp but thought I'd post this for comments and discussion. The reverb idea could be good for other amps also like Marshalls etc....
Tubenit
« Last Edit: December 09, 2007, 09:21:42 am by tubenit »
Offline Fresh_Start
  • noob de Lux
« Reply #39 on: December 09, 2007, 09:57:34 am »
Tubenit - two (ignorant?) questions:  did you select the 5uf cathode bypass caps for the reverb driver & return to reduce a certain amount of bass in the reverb?
Also, have you tried using a single 12AT7 instead of a single 12AX7?  I realize that the recovery stage would fall short on gain, but think that there would be more current driving the reverb tank.
My apologies if this is too far off topic.
Chip
Quote from: jjasilli
Quote from: PRR
« Reply #40 on: December 09, 2007, 10:50:28 am »
I haven't built a D'Lite and have no plans to at this point. Simply reporting what others seems to have found successful including the 5uf and the 12Ax7.
Just trying to create some dialogue and thought among the successful builders here on using that design.
If you look at Hoffman's "add reverb to a Western circuit" layout, he uses .68uf with 820R for his one tube reverb. I did that with a Marshall clone I made and it worked great. My guess is oscillation is less of an issue within the reverb more highs and fewer mids/bass being verbed.
I have used a 6.8uf and found it helped tame the reverb a bit.
Offline jgriffes
« Reply #41 on: December 11, 2007, 08:29:53 pm »
well, i finished the umblot lite.  After corrrecting a few stupid mistakes,  she's rockin.  anyway, the clean sounds pretty good, but the distortion channel sounds a little(for lack of a better word) ragged.  I do however have a pair of crappy 5881's in the power section and plan on picking up a pair of 6v6's tommorrow. hope fully this will help.  thanks phsyco for all the help, i'll get it ironed out i'm sure.
« Reply #42 on: December 13, 2007, 12:50:38 am »
Just remember the output impedance changes with 6v6's.Double the speaker impedance with 6v6's.
Here's a shot of the Reverb Rocket in progress.Still waiting for a 2 meg pot for the reverb.
« Last Edit: December 13, 2007, 01:01:39 am by phsyconoodler »
« Reply #43 on: December 14, 2007, 11:56:30 pm »
Here's a shot of the completed amp.Just have to test it and finish the cabinet.
Offline jgriffes
« Reply #44 on: December 15, 2007, 12:52:34 am »
hey physco, installed the 6v6's, sounds alittle better.  the disortion is still farty sounding a bit. the distortion is not really that smooth sounding.  what cuases this?  cold solder joint?  any help would be great.  by the way, I used one of those impedence selectors for hammond trannies.  it was worth the 15 bucks, but i am not sure which wire to hook the neg feedback to.  thanks for all the help, i really appreciate it.  by the way, your new build looks kick ass!  that is some clean work my friend.
Offline navdave
  • 559
« Reply #45 on: December 15, 2007, 04:02:41 am »
Whats the PAB switch do?
« Reply #46 on: December 15, 2007, 12:24:57 pm »
The PAB is preamp boost.
  Not sure why you don't have better sounding distortion.Did you install the trim pot for V2 bias?If so,turn it up higher.
Hook the neg feedback wire to the + of the speaker jack.
« Last Edit: December 15, 2007, 12:26:00 pm by phsyconoodler »
Offline LooseChange
    • Fix Your Darn Amps
« Reply #47 on: December 15, 2007, 12:30:01 pm »
Hey Physc, You have confused me.. The subject is *umbolt Lite.  Whats the Reverb Rocket??
Call me Dan
www.fydamps.com
« Reply #48 on: December 15, 2007, 12:35:37 pm »
It's my name for my version of the amp.Actually I toss that name around rather than the *umbolt one.
 The faceplate says 'overdrive rocket' The reverb works great but I'm having other problems I need to sort out.
Offline LooseChange
« Reply #49 on: December 15, 2007, 12:41:08 pm »
But these recent pictures are a different amp than the other pictures on page 1 of this thread, right? (I gotta learn to keep up.)
What kind of problems are you having?
Call me Dan
www.fydamps.com
