September 18, 2026, 03:27:01 am
Hoffman Amps Forum image Author Topic: Conversion from a GZ34 to diode rectification  (Read 5534 times)
Offline Superchet
« on: May 05, 2014, 06:56:44 am »
Does anyone have the diagram(s) for the mod(s) showing where the solid state diodes should be wired under the GZ34 socket replacing the GZ34?
Cheers.
Re: Conversion from a GZ34 to diode rectification
« Reply #1 on: May 05, 2014, 07:34:51 am »
Cheers.
Connect anode of a diode to pin 4 and cathode to pin 8. Connect anode of second diode to pin 6 and cathode to pin 8.
« Reply #2 on: May 06, 2014, 07:55:27 am »
I would like to use the base from a broken octal tube
and solder the diodes in the base, so, if I want, I can take it off and put on a Tube Rectifier
You may also consider to add an in-series resistor for SAG purpose (or to drop a bit the voltage)
« Last Edit: May 06, 2014, 07:58:01 am by kagliostro »
