September 08, 2026, 10:02:22 pm
Hoffman Amps Forum image Author Topic: The chassis are here  (Read 96593 times)
Offline lego4040
Re: New Chassis plans
« Reply #100 on: October 09, 2014, 04:05:27 pm »
Ill take one with holes please
« Reply #101 on: October 09, 2014, 05:21:03 pm »
doug change my reservation please...
2 blank and 2 punched.
thanks,
« Reply #102 on: October 09, 2014, 06:24:25 pm »
I would like to get 2 with the pre-drilled holes, please.
Do I watch your catalog and wait to order, or can I pre-order them now?
Thanks, Ken
Hi ken,
I'll announce here when I have them in and ready to order
« Reply #103 on: October 09, 2014, 06:26:19 pm »
4 blanks left if I have counted right
« Reply #104 on: October 10, 2014, 07:16:30 am »
I think you are right on count, but what I need some other stuff.  Should I just order it at the same time from you? :icon_biggrin:
You know when chassis are needed so are turrets, eyelets.  BTW, I have never used it, but a LOT of folks really like your 18 watt iron.
« Reply #105 on: October 10, 2014, 07:23:04 am »
Thanks Ed
The 18 watt iron is Heyboer iron and I get them from Mojo
Mojo is the major Heyboer distributor
I sell them at the 100 piece price, so it is cheaper to buy Mojo stuff from me than it is on the Mojo web site
I have a deal worked out with them on that
The same thing goes with anything you see on the Mojo site
I can get it for you guys way cheaper
« Last Edit: October 10, 2014, 07:32:27 am by EL34 »
« Reply #106 on: October 10, 2014, 09:02:13 am »
 :sad: :sad: :sad:
I really hope you open a branch on this side of the pond
or Italy change the policies of import from the USA
« Reply #107 on: October 10, 2014, 09:30:40 am »
I'd like to get one with holes.
I also noticed that there's a couple things on the Mojo site I need too...nothing real expensive, but why pay shipping twice if I don't have to ....are the chassis getting drop shipped from Mojo?
How should I proceed?.....I don't have a ton of stuff to order, but I figure it might look good if they see buisness coming from here..... I have never ordered from them before now.
« Reply #108 on: October 10, 2014, 09:55:32 am »
:sad: :sad: :sad:
I send stuff to Europe and the Uk all the time
But I don't remember having anything going to Italy
Must have some tough import duties
« Reply #109 on: October 10, 2014, 09:57:35 am »
Just give me the Mojo items numbers and I will add them to my weekly Mojo stock order
Use their 100 piece pricing as your price
If they are small items, the shipping will not be much if you pick first class shipping
no need to wait for the chassis to arrive here
« Reply #110 on: October 10, 2014, 11:03:30 am »
Doug,
I get confused easily so I need to ask.  If I want to get something from Mojo I can include the number on a order to you and you will sell it at the 100 count price?
Is it limited to certain things or anything?   No woodshop? Correct.  Guitar parts?
Just amp parts
« Reply #111 on: October 10, 2014, 11:09:17 am »
I'll have to ask Andy about cabinets
I think it applies any of the items they they have in stock and are ready to ship that day.
Cabinets and stuff are a different shop and have a long wait before they are done
yes, you can email me with the mojo item numbers but if I don't already stock it, I would have to put it on my next stock order to save some shipping cost.
Of course I can just order it that day and get it coming but I would have to tack on the shipping cost
Other wise, I won't add extra shipping cost if I can do it as part of my regular weekly stock order
Mojo is in NC also and I get stuff in one to two days from them, so the shipping timeframe is very short
« Reply #112 on: October 17, 2014, 09:10:18 am »
EL34,
Do you have a DXF file of the chassis you are making.  The flat inside, front and back?
« Reply #113 on: October 17, 2014, 09:15:51 am »
Andy at Mojo has that
That is the property of Mojo and something he does not give out because of all the work he put into it
« Reply #114 on: October 17, 2014, 09:21:55 am »
That is cool.  I usually can get the PDF from them and they normally do not secure it.  I can make an editable from that.
Offline jeff
  • Need input
« Reply #115 on: October 17, 2014, 04:11:28 pm »
I like it. And if I were to build a 6V6 amp I'd consider buying it. But, even though the 9pin socket adaptor is a good idea, as far as only having to stock one type of chassis, there is something to be said about the clean look of not having to use an adaptor. To me that would always bug me, having to cover up an oversized hole with an adaptor. Personally I'd like a chassis with 9pin socket holes, because then I could drill them out bigger if I decide to go with 6V6. But that's just me some people wouldn't want to have to deal with that and don't mind an adaptor.
 I built an amp with a 6V6 and decided to swap it for another tube and had to use an adaptor. It urks me every time I look at it, It just looks wrong. I see it as covering up a miskate. I don't think I ever get used to it and was actually considering redoing the chassis for a while. There's nothing wrong with it, I just personally don't like it.
I dunno I guess I like the cleaner look of no adaptors, but if you're only going with one style I guess that'd be the way to go. Honestly, I might buy it for a 6V6 amp but I would not buy it for a EL84 amp.
« Last Edit: October 17, 2014, 04:16:00 pm by jeff »
« Reply #116 on: October 17, 2014, 05:02:38 pm »
"Personally I'd like a chassis with 9pin socket holes, because then I could drill them out bigger if I decide to go with 6V6."
That's only part of the reason I want no holes for mine. Everyone should own a step drill bit anyways. After all, this chassis is for an EL84 based amp so the holes should be sized for those to begin with.
« Reply #117 on: November 02, 2014, 04:20:49 pm »
It's taking a long time for Andy to get the chassis
He says that I should have them around the 10th of November
I'll post back when I have an exact arrival time
« Reply #118 on: November 10, 2014, 09:32:16 am »
Alright, I have iron and parts.  What is up, you guys still mining?
« Reply #119 on: November 10, 2014, 09:40:41 am »
Supposedly Friday or today is the date they arrive at Mojo
I emailed Andy to see what's up
I'll post back when he replies
« Reply #120 on: November 12, 2014, 09:41:44 am »
Andy was away for a few days.
I just got an email from him.
He said he was going to have a firm ship date for me later today
Cross your fingers
« Reply #121 on: November 13, 2014, 05:38:40 am »
Email from Andy
Ok we will be shipping to you either Friday or Monday.
« Reply #122 on: November 17, 2014, 11:39:47 am »
Andy says the chassis are shipping today
If they really do ship today, they would be here tomorrow
I'll keep you guys poste
« Last Edit: November 17, 2014, 03:13:03 pm by EL34 »
« Reply #123 on: November 17, 2014, 06:05:14 pm »
was the mojotone TW-35 output xformer on the ship list? or should we do that on a separate invoice?
Re: The chassis are here- get your now at special forum price
« Reply #124 on: November 17, 2014, 06:07:57 pm »
No, Andrew is going to ship it to me free as soon as he gets it.
I don't think they sell many of those
You may have gotten the only one they had on the shelf
Re: The chassis are here- get yours now at special forum price
« Reply #125 on: November 17, 2014, 06:16:16 pm »
Got the order, thanks Pete
« Reply #126 on: November 17, 2014, 06:17:58 pm »
too bad - it's an excellent sounding OT. i highly recommend it for Deluxe and "Super" Deluxe type amps.
you're welcome!
« Reply #127 on: November 17, 2014, 06:24:06 pm »
Andrew said that Heyboer is shipping them some
Not sure what the hold up is
Probably was not on the shelf and heyboer has to wind them
« Reply #128 on: November 17, 2014, 06:35:20 pm »
Got the order Ken Moon, thanks
« Reply #129 on: November 17, 2014, 08:09:22 pm »
Got the order Doug- terminalgs, thanks
« Reply #130 on: November 18, 2014, 05:03:08 am »
I got the UPS tracking number from Mojo. The chassis will be here today
I just added the chassis to the top my chassis page here at the special forum price of $39
http://hoffmanamps.com/MyStore/catalog/parts6.htm
I will be upping the price as soon as you guys get yours
I don't have any pictures yet
I'll have it all set up better once I get the chassis here, but for now this will let you get them ordered
The parts number is
ChassisStout1 for the blank chassis
ChassisStout2 for the punched chassis
This is the list I have so far so I can keep track of who wanted what
I received orders from
2 blank - 2 punched - Dummyload
2 blank - jojokeo
1 punched - terminalgs
2 punched - Ken Moon
2 blank  - 2 punched - Ed Chambley
I have not received orders from
1 punched - lego4040
If I have the counts correct
6 blanks sold
8 punched sold
« Last Edit: November 18, 2014, 08:20:05 am by EL34 »
« Reply #131 on: November 18, 2014, 09:03:10 am »
Damn Douglas, you better get me out of the bolded area.  What ya gonna do is someone doesn't pay, you gonna send your Hillbilly Hitman?
« Reply #132 on: November 18, 2014, 09:11:00 am »
No bold for you
No one comes to the door, you just loose the $39 initial offering price  :icon_biggrin:
Probably gonna move the price up to $45 later today
« Reply #133 on: November 18, 2014, 02:35:54 pm »
Pics and info on the new chassis here
http://el34world.com/Forum/index.php?topic=17858.0
« Reply #134 on: November 18, 2014, 03:32:40 pm »
... didn't notice the post until I went looking for the old "New chassis plans" thread
Order IN
Don't be so sensitive....geeeeezzzz
some of us didn't get to be bold.... :cry:
Offline lego4040
« Reply #135 on: November 18, 2014, 03:39:46 pm »
Payday tomorrow for me, will get it in
« Reply #136 on: November 18, 2014, 04:25:50 pm »
Order IN
Alright, have your fun whilst you can.  I remember everything. :cussing:
« Reply #137 on: November 18, 2014, 04:27:20 pm »
Lego, add a note to your order to remind me about the special price
They are listed at $45 now
Offline lego4040
« Reply #138 on: November 18, 2014, 06:31:33 pm »
 :thumbsup:
« Reply #139 on: November 21, 2014, 01:47:06 pm »
package received today. quality stuff. thank you!
i measured the temolux PT today. looks like i need to shave about 75-80mils total to fit: 100mils to clear any tolerance variations.
doug, any word on that tw35 OT from mojo?
thanks,
Offline Ken Moon
« Reply #140 on: November 21, 2014, 02:37:29 pm »
Early Xmas  :icon_biggrin:
Thanks, Doug - now all I need are a couple of 18watt PTs  :headbang:
« Reply #141 on: November 21, 2014, 02:53:34 pm »
Got em in stock ken and discounted
http://hoffmanamps.com/MyStore/catalog/parts1.htm
Pete,
I'll email Andrew at mojo again
Offline terminalgs
« Reply #142 on: November 21, 2014, 09:23:11 pm »
My order arrived today. Great chassis. I'll be ordering another!
« Reply #143 on: November 22, 2014, 04:35:36 am »
Let the projects begin
I'll be doing a Stout in mine and document that build
« Reply #144 on: November 22, 2014, 12:46:17 pm »
Ciao Doug
At DIYItalia we are starting to draw a layout for the board of this amp
http://www.bensykora.com/7cylinder.html
that will be based on your chassis, it seems it will be a perfect fit (better than original)
p.s.: I sent a pair of Vox schematic (after the refiniment of Vox AC15 schematics, did you received it ?)
« Last Edit: November 22, 2014, 01:01:23 pm by kagliostro »
« Reply #145 on: November 22, 2014, 01:31:11 pm »
Thanks Franco
Yes I uploaded your Vox schematics
Offline rlh5599
« Reply #146 on: November 23, 2014, 07:38:44 pm »
Hey Doug,
I been following along here and on FB...  Did I miss the intro price?  I'd like a punched chassis, and I'll order some parts too, to save on shipping...
Ralph
Ralph Henderson
« Reply #147 on: November 23, 2014, 08:04:33 pm »
Hi Ralph,
The punched chassis are all gone, I'll have more in a week at the $45 price
The special deal was only for those that stated what they wanted before they arrived
I did not make anything on those special deal chassis
I have to pay the bills on any sold from now on
« Last Edit: November 23, 2014, 08:10:36 pm by EL34 »
Offline rlh5599
« Reply #148 on: November 23, 2014, 08:11:22 pm »
no worries, gives me a chance to figger what parts I need without being in a rush..
Thanks!
Ralph Henderson
Offline Ken Moon
« Reply #149 on: November 26, 2014, 04:23:09 pm »
Here's a pic of the new chassis with 18watt iron (the choke is a Mojo 6V6 amp choke, it looks just like the Weber W02299. The Heyboer HY02299 (open coil, 9H/120mA/125R) will also fit the mounting holes.
I'm going to start with a 6V6 version of the DaisyCutter by Randy Fay (Phaez Amps), with the obvious changes to use 6V6s:
I'll be putting it in a heads-up combo similar to this old prototype cab:
with cosmetics that look something like this (different front panel of course)
I'll post progress (and probably some questions) in a separate build log post.
Happy Thanksgiving, all  :icon_biggrin:
