September 16, 2026, 02:00:18 am
Hoffman Amps Forum image Author Topic: noise coming from reverb recovery circuit  (Read 27719 times)
Offline Leevi
    • Rikstone
Re: noise coming from reverb recovery circuit
« Reply #50 on: June 20, 2020, 09:45:45 am »
I have met this issue some times before and fixed those by doing different kind of rewirings/changes in the circuit but never noticed this simple rule. I have learned it now and hopefully I will remember it as well.
Leevi
« Reply #51 on: June 20, 2020, 11:03:49 am »
Here's a direct link to Hoffman's amp grounding scheme. It can also be easily accessed through the Tube Amp Library link at the bottom of this page...
     https://el34world.com/charts/grounds.htm
Well worth reading. Maybe even save the link for future reference.
Offline Leevi
    • Rikstone
« Reply #52 on: June 20, 2020, 02:41:31 pm »
Thanks for the link sluckey
/Leevi
Offline Leevi
    • Rikstone
« Reply #53 on: October 09, 2021, 02:31:31 am »
Want to share here another case I met recently.The amp was a point-to-point converted DRRI where the reverb was noisy even if the recovery input was grounded.I spent lot of time with it trying to move the grounding of the recovery cathode. By moving the 220K grid leak resistor to the grid and grounding it to the ground bus helped a bit. The biggest impact was when I replaced the foot switch jack to an isolated one and grounded it to the ground bus. The noise decreased more than 50% and it is now on acceptable level.
/Leevi
« Last Edit: October 11, 2021, 03:44:45 am by Leevi »
