September 08, 2026, 10:47:30 pm
Hoffman Amps Forum image Author Topic: JSchem now working again for Apple OSX10.10 (Yosemite)  (Read 12634 times)
« on: October 17, 2014, 03:14:15 am »
Edited - workaround for problem - see bottom of thread
When you 'upgrade' to OSX10.10 and then try to open JSchem, you get a message that comes up saying "You can’t open the application “JSchem” because PowerPC applications are no longer supported."
Dayum (you might think). Read the fix further down the thread.
« Last Edit: February 13, 2015, 07:06:00 am by tubeswell »
Offline simonallaway
    • Hot Bottles - Tube Amp Blog
Re: JSchem no longer working on Apple's new OS X (Yosemite)
« Reply #1 on: October 17, 2014, 09:58:20 am »
I think that's somewhat incorrect. PowerPC applications haven't been supported for quite some time. I think it's having trouble with the Java runtime environment. When I logged in after upgrading to Yosemite it whined about me needing to install the Java 8 runtime (in this case for the Adobe updater). This might help:
http://support.apple.com/kb/DL1572
« Reply #2 on: October 17, 2014, 12:34:39 pm »
Thanks for that. I'm running Java 7 from Oracle. This is a fix apparently
http://support.apple.com/kb/ht5559
I'll check it out.
« Reply #3 on: October 21, 2014, 12:26:19 pm »
I'll check it out.
Well that didn't work. I messaged Bernhard
« Reply #4 on: February 12, 2015, 07:35:36 pm »
I've just heard from Bernhard after a short hiatus. He's very generously started looking at the problem again - hopefully it'll all be up and running again soon in OSX10 Yosemite.
« Reply #5 on: February 13, 2015, 04:12:30 am »
Yay its working again if you re-download the version in the link for Macs and install Legacy Java SE 6 for mac.
http://thegothicparty.com/dev/article/how-to-install-legacy-java-se-6-runtime-for-mac-10-10/
(At least on my Macbook Pro it is working again - altho' I can't access the extensive library of components I had built up in the old version of JSchem. However, JSchem is still hanging up on my mid 2011 iMac desktop, which is running the same OSX10.10. I emailed Bernhard again)
« Last Edit: October 21, 2015, 12:11:04 pm by tubeswell »
