September 17, 2026, 07:41:33 pm
Hoffman Amps Forum image Author Topic: Hotrod Deluxe Power Supply Caps  (Read 4091 times)
Offline Jack1962
  • I love AMPS, Tube or SS
    • Latham Electronic Systems
« on: November 23, 2014, 11:02:26 am »
in the hotrod deluxe they use a voltage multiplier in the power supply , using 8200pf 1Kv caps(4) . would it make much difference if any if they where replaced with 10000pf 1KV caps ?
Re: Hotrod Deluxe Power Supply Caps
« Reply #1 on: November 23, 2014, 11:47:44 am »
Hmmm, the schematic I see uses a standard FWB with a single 8200pF across the AC input to the bridge, but I see no reason to not just use a .01µF.
Edit... found a later schematic of a HR Deluxe/Deville that does have a cap across each diode of the bridge. I'd still use .01 caps if I could not find 8200pF.
« Last Edit: November 23, 2014, 12:00:40 pm by sluckey »
Offline Jack1962
« Reply #2 on: November 23, 2014, 12:04:33 pm »
Thanks Sluckey , could you either post that later HR Deluxe/Deville schematic or the link to it ?
Offline Jack1962
« Reply #4 on: November 23, 2014, 12:46:07 pm »
Thanks that's the monster  :thumbsup:
