September 18, 2026, 10:52:55 am
Hoffman Amps Forum image Author Topic: Is this a good idea?  (Read 4079 times)
Offline Leevi
    • Rikstone
« on: March 07, 2015, 02:47:44 am »
I have a simple PT that only have 6,3V and 250V secondaries.
I would like to use it with 5Y3 rectifier and I'm thinking a solution how the PT could be adapted for 5Y3.
See the attached picture.
I see at least the following problems:
- High DC voltage on the tube heaters
- 6,3 V filament reference point, the resistors must be big in order to keep current low.
/Leevi
Offline AZJimC
  • What a pretty glow!
Re: Is this a good idea?
« Reply #1 on: March 07, 2015, 03:05:59 am »
I don't see a way your 6.3vac could be balanced to ground without providing a path to ground for the B+. I'd think about using an EZ81. It has 6v heater, and cathode is not connected to heater. Also could look at other variants in octal if you prefer. Look at a 6AX5GT. It is similar, but in octal basing
Offline Leevi
    • Rikstone
« Reply #2 on: March 07, 2015, 03:09:31 am »
Yes I agree, EZ81 is a better alternative for this.
/Leevi
« Reply #3 on: March 07, 2015, 03:09:48 am »
+ 1 for AZJimC
The 5Y3 cathode is directly heated, if you use this kind of tube you'll have B+ on filaments and that is'n a good thing to do
EZ81 is the solution, reserve the 5Y3 for one other project
Offline darryl
    • ValveTone Amplification
« Reply #4 on: March 07, 2015, 03:27:10 am »
If there is space on or under the chassis, a 2 amp filament transformer could be installed, to provide an electrically isolated supply for the rectifier's heater.
