September 17, 2026, 08:17:46 am
Hoffman Amps Forum image Author Topic: Ampeg V-4BH low output  (Read 3580 times)
Offline BigE
  • Fender guy...
« on: March 30, 2015, 08:25:07 am »
I've got an Ampeg V-4bh that suffered a fall from the cab it was sitting on.  Now there is hardly any output our of the mains.  Swapped Tubes and no change.  Chop-sticking doesn't reveal anything.  Can't see anything broken or loose.
Here are my voltages:
V1
1 - 220   6 - 218
2 - 0       7 - 0
3 - 3.7    8 - 1.8
V2
1 - 346    6 - 220
2 - 71     7 - 2.5
3 - 113   8 - 4.5
page 2 schematic:
V1:
1 - 230   6 - 270
2 - 0       7 - 50
3 - 1.7    8 - 102
v2:
1 - 281   6 - 276
2 - 0       7 - 0
3 - 15     8 - 15
Power tube voltages:
3 - 485
5 - -47
8 - 0
voltage at "bias" point in schematic is -48
+- 10v are right on
High voltage drops look OK.
Not sure where to start since I can trace signal all the way through the thing. And you do get output but you have to Max the thing to get any signal out.
Thanks in advance.
Re: Ampeg V-4BH low output
« Reply #1 on: March 30, 2015, 08:40:20 am »
usually mechanical hits cause mechanical breaks, I'd still look for that.
Listening or scoping?  I'd think either would show where the signal gets anemic
Offline BigE
  • Fender guy...
« Reply #2 on: March 30, 2015, 08:45:37 am »
With a listener box i traced the signal.  I figured on the power tubes it would be non existant but it seemed pretty solid.
