September 13, 2026, 09:19:56 pm
Hoffman Amps Forum image Author Topic: troubles with turrets from CE dist?  (Read 6786 times)
Offline markmalin
  • Malin Sweet Loraine
    • Malin Amplification
« on: May 16, 2015, 10:34:34 am »
Just curious...this is the first full turret board I've done - I normally use eyelets.  I bought the turrets from CE Dist, but for the life of me I can't get the solder to wet properly.  They just all seem like cold soldier joints.  Before I go much further, I wanted to ask if anyone's dealt with this?  I can ditch these boards, drill new ones and buy turrets from Hoffman (which I will next time!) but for the sake of saving these boards, any advice?  I'm trying flux paste but what a hassle for EVERY turret.  Thoughts??
Thanks guys!
Mark.
"... there are Flying V's and then there are the ones shaped like peanuts..."  - my son at age 9
Re: troubles with turrets from CE dist?
« Reply #1 on: May 16, 2015, 11:11:15 am »
Bad plating is the cause
Saw someone on facebook saying the same thing
http://hoffmanamps.com/MyStore/catalog/BoardBuilding.htm
Offline markmalin
« Reply #2 on: May 16, 2015, 11:31:03 am »
argh....
Well, I just ordered 150 from you :)  Now it's off to the shop to cut and drill new boards.  Live and learn...
« Reply #3 on: May 16, 2015, 12:02:06 pm »
A good while back I had bought a generic turret board from AES. It was like the Fender tag strip but with lugs installed. I had the same problem. By the time I'd get 'em hot enough to melt solder, the fiber board would start smoking. Lesson learned.
« Reply #4 on: May 16, 2015, 12:38:08 pm »
The plating on the lugs is junk
I had a bad batch about 15 years ago from the guy that makes mine for me
Solder would not stick
He found out the plater had screwed up and sent me a new bacth
they are brass inside and made on a screw machine
then my guy sends them off to be plated
Offline markmalin
« Reply #5 on: May 16, 2015, 02:20:50 pm »
that's exactly what's happening.  The solder will not stick.  No matter how hot I get them.  It's a bugger because it's going to set the delivery of these two amps back about a week, but at least I know the ones I'm getting from Hoffman are going to work -- and it gave me the chance to cut and drill out some translucent red fiber board I had bought :)  That should "look the business" when it's done!
« Reply #6 on: May 16, 2015, 04:44:57 pm »
The custom lugs I have made have really nice coatings
« Reply #7 on: May 16, 2015, 05:29:47 pm »
after enough repetitions of re-heating, the solder will eventually leech the Sn plating and solder not sticking issues surface. use the hole and bond parts and wires in them is a solution, but messy.
the EL34 cathode bias princeton i was building suffered from the issue described above - reused and re-worked the original turret board a third time. it's now sitting in a corner awaiting a decision of disposition because it looks like s#!7 and some of the connections are dubious.
i doubled my workload because i was cheap... :-/
Offline markmalin
« Reply #8 on: May 16, 2015, 05:37:23 pm »
I can relate :P
I'm really trying to do this right the first time.  I stewed and stewed about whether to try something else...like wire through the turrets like you said...or douse every connection in flux, but at the end of the day I kept telling myself "anything worth doing is worth doing right".  Not to mention someone is going to pay me a lot of money for this amp, so I've got to get it right and not have to lie awake wondering if a cold solder joint is going to show up during one of someone's gigs!  lol
Offline hardhead
« Reply #9 on: May 19, 2015, 12:19:52 pm »
Be sure to make it a "fool me once"experience
« Reply #10 on: May 19, 2015, 12:59:54 pm »
Have you tried adding add'l liquid or paste flux?
That would utterly suck, to put the thing together and have the solder joints look like crap.
Offline markmalin
« Reply #11 on: May 19, 2015, 01:09:25 pm »
I did.  I ended up slobbering flux all over a couple turrets and finally after soldering was not able to forceably unwrap a wire (an old technician's trick to detect cold solder joints is to grab the wire with a needle nose and try to pull it off).  I couldn't get it off, but solder only seemed to wet into that section of the turret.  In other words, even though I smothered the entire turret with flux and heated it up like crazy, solder only stuck to the half of the turret where the wire was -- nothing would wet to the other half.  That's when I decided, for the amount of money that's being paid for these amps, I just can't deliver work like this and feel good about myself.  So I ordered new turrets and will completely rebuild the boards.
« Reply #12 on: May 19, 2015, 01:13:28 pm »
It's not worth messing with them
I have found that when the plating is not right, there's nothing you can do to get solder to stick
