September 13, 2026, 05:00:26 pm
Hoffman Amps Forum image Author Topic: Re: Hi/Low power.  (Read 4272 times)
Offline pinkphiloyd
Re: Hi/Low power.
« on: May 20, 2015, 01:56:41 pm »
I've been thinking about this, out of boredom as much as anything else, really.
I've seen the hi/low power option on tube amps approached from a couple of different directions.  It usually comes back to lifting (or switching  a large resistance in series with) the cathodes of 2 power tubes.  Opinions on the sonic results of this method seem to vary considerably.  So (everybody stand back!) I got to thinking about all of this...
If your PT had multiple primaries, say 120 and 220 V for the sake of conversation, and you're living in a country with ~120V line voltage, what would the results be if you utilized a switch that switched your line voltage input between the two primaries for hi and low power modes, respectively.  I know this would effect the heater voltages... any other problems?
Re: Hi/Low power.
« Reply #1 on: May 20, 2015, 02:41:04 pm »
Probably work similar to an on/off switch.  :icon_biggrin:
If you feed 120v into a pt that expects 240v, then all the secondary voltages will be 1/2 the expected voltage. Some tubes will probably choke.
If you have a variac you can simulate this for yourself. Just dial it down to 60v. Does the amp like it?
Re: Hi/Low power.
« Reply #2 on: May 20, 2015, 02:49:54 pm »
The big problem is the heater voltage
to half B+ will give the effect of an early compression like using a VVR
but if at the same time you half the heater voltage, easily the amp will not work
and assuming it do, it will happen in a bad way
Offline AZJimC
  • What a pretty glow!
Re: Hi/Low power.
« Reply #3 on: May 20, 2015, 04:23:47 pm »
Having tinkered with voltage reduction methods for lower power settings, I can say I much prefer to drop voltage only to the power tubes, while allowing the preamp full voltage. My current goto amp has a switch that places a large resistor in screen circuit, which allows easier power tube overdrive more so than dropping power, not much volume reduction. Then it switches in a large resistor on plate power to offer even more distortion, still not a lot of volume drop. Lowest power setting would be about 1/3 power, which still won't get it into bedroom volume, so a LARMAR type master vol helps tame it even more.
Allowing the heaters to drop to half would likely render the tubes too cold to do much at all.
Offline pinkphiloyd
Re: Hi/Low power.
« Reply #4 on: May 21, 2015, 10:11:09 am »
Well, that's why I asked.   :icon_biggrin:
