September 10, 2026, 03:14:57 pm
Hoffman Amps Forum image Author Topic: Someone say the 6P15P is a good for audio and usable as el84 ... is it real?  (Read 7763 times)
Sometime happens to read that the 6P15P (6П15П) is an equivalent of the EL83 - SV83 tube
claimed to be a good tube for Audio output purpose (and usable as an EL84/6BQ5)
6P15P datasheet
http://www.mif.pg.gda.pl/homepages/frank/sheets/113/6/6P15P.pdf
EL83 spec
http://www.r-type.org/exhib/aad0120.htm
EL83 datasheet
http://www.r-type.org/pdfs/el83.pdf
SV83 datasheet
http://tdsl.duncanamps.com/link.php?target=0025A893
EL84 (6BQ5) datasheet
http://tdsl.duncanamps.com/link.php?target=00259D83
Have you any experience about ?
What is your thought about ?
« Last Edit: May 29, 2015, 09:16:45 am by kagliostro »
Offline Toxophilite
I've used the 6P14P (7189 equivalent) in hifi and guitar amps and found it to be a perfectly good tube
Thanks Toxophilite
I know the 6P14P (6П14П) tubes and I've some
now I'm curious about the 6P15P
« Last Edit: May 29, 2015, 03:14:08 am by kagliostro »
Offline jazbo8
6P15P is closer to the EL84 than the EL83, and can be used as a substitute with the g3 pin connected to the cathode externally.
« Last Edit: May 29, 2015, 03:47:20 am by jazbo8 »
300V 9W = 10k load resistance
I saw a bunch of Russian EL83s going for a song the other day
Thanks Jazbo8 & Tubeswell
