September 15, 2026, 12:33:29 pm
Hoffman Amps Forum image Author Topic: Aluminium chassis thickness  (Read 7216 times)
Offline Toxophilite
« on: September 27, 2015, 10:33:40 pm »
I have some old organ back aluminium
It's .051 inches thick or about 1.29 mil
Seem pretty skookum
Would this be thick enough for a chassis of a medium sized amp? say 30-40 watts
Offline FranciscoPerez
    • 22 nanofarads
Re: Aluminium chassis thickness
« Reply #1 on: September 28, 2015, 03:29:23 am »
Guess it would depend on how it's bent. I've gone a bit thinner than that in some narrow-panel builds with no issues.
« Reply #2 on: September 28, 2015, 03:48:20 am »
I use aluminium chassis all the time and the sheet metal guy I use only has 2.5mm and I would not like to use anything much thinner than that. There is one problem I have with the 2.5mm aluminium is if I use plexi faceplates, these are usually about 2mm thick, the bushings on pots are only just long enough to get the nut on.
« Reply #3 on: September 28, 2015, 06:37:50 am »
If the amp isn't larger than a 30W I suggest a 2mm thikness for aluminium chassis
« Reply #4 on: September 28, 2015, 06:38:52 am »
If you're just using the .51 for your own build that you'll be using, it'll probably be "good enough". Once the chassis fastened in the cabinet, it helps to stiffen it up. Although it'd probably be better used for an 18 watter or less.
Naturally, thicker is always better. But using whatcha got is good too. ;)
Offline uki
  • Hot Tube Hot Sound
    • Uki's Guitar Trip
« Reply #5 on: September 28, 2015, 07:07:08 am »
Seem pretty skookum
That will probably do, for a larger chassis would be better to use 2mm, so it wont bend with the weight of the transformers.
https://soundcloud.com/ukiuki
Offline Toxophilite
« Reply #6 on: September 28, 2015, 10:03:31 am »
Thanks. I might save it for a lighter build. I have a hankering for a champ ever since I gave away a reissue one to my brother.
« Reply #7 on: September 29, 2015, 08:07:43 am »
I sell chassis that are .090 inch thick
I don't think I would use anything thinner than that
It's really easy to bend an aluminum chassis if it has decent sized transformers
« Reply #8 on: September 29, 2015, 07:21:19 pm »
All the amps I built in the old days were .125 inch thick 6061
never seen a problem with those
.090 is the minimum I would build with as far as I am concerned
Offline Toxophilite
« Reply #9 on: September 29, 2015, 07:38:46 pm »
hmm Maybe I'll save it for face plates. little boxes , patches what have you
Thanks for all the suggestions and advice!
