September 13, 2026, 01:11:04 am
Hoffman Amps Forum image Author Topic: peavey valveking vk212  (Read 5642 times)
« on: February 05, 2016, 05:36:44 pm »
need a schematic. i emailed peavey but no response yet. anyone have a copy?
TIA,
Re: peavey valveking vk212
« Reply #1 on: February 05, 2016, 09:48:02 pm »
Usually Peavey is quite responsive. I have one of these, bot used for $190. Unbeatable deal. I have pretty much replaced my SF hopped-up Princeton Reverb with it because it's kind of an expendable amp, for gigs and hauling around. If it's yours, replace the stock speaker which is really, really bad. I think these are entirely respectable amps, although some early ones had some irritating little snarks with them. You or I could not buy the parts to build a PP 6L6 amp w/3 12AX7 in a proper tolexed cabinet with reverb and 2-channel switching for what these go for used.
Try this:
http://www.thetubestore.com/lib/thetubestore/schematics/Peavey/Peavey-Valveking-112-Schematic.pdf
Offline Leevi
    • Rikstone
« Reply #2 on: February 06, 2016, 01:15:25 am »
Probably the same version can be found here?
http://peavey.com/forum/viewtopic.php?t=34996
/Leevi
« Last Edit: February 06, 2016, 01:18:23 am by Leevi »
« Reply #3 on: February 06, 2016, 01:30:53 am »
/Leevi
thanks! that's the one.
« Reply #4 on: February 06, 2016, 03:18:31 am »
http://el34world.com/charts/Schematics/files/peavey/Valveking%20212.pdf
I don't understand if the schematic was previously on Doug's database, but at the moment it is there
