September 20, 2026, 07:22:32 am
Hoffman Amps Forum image Author Topic: First build tranny ?? (ao-44)  (Read 8135 times)
Offline asat
« on: February 11, 2016, 07:06:44 pm »
Hi, just joined today, posted a hello in the intro forum and also asked about the possibility of using a Hammond ao-44 to build a Plexi 6v6 - I saw that sluckey did it with an ao-43 and was hoping the -44 is close in design.... I also have an ao-29 amp and an old Magnatone MP1 that I can rob from if needed....  was planning on doing a SE for a first build but the layout and schematics on sluckeys site make me feel like I could go bigger with a little help...... thanks for any advice......
Lou
In Pleasant View
« Last Edit: February 11, 2016, 07:56:47 pm by asat »
Offline Mike_J
Re: First build tranny ??
« Reply #1 on: February 11, 2016, 07:18:09 pm »
Hi Lou
This is a great site with some very knowledgeable people willing to help.  My first advice is not to steal from the Magnatone.  A vintage amp should be kept intact.  I made some changes to a silver faced Super Reverb that sounded good but wasn't a blackfaced Super Reverb.  Made changes to make it look like a blackfaced amp and reduced the value of the amp.  Best to leave vintage guitar amps alone in my opinion with the exception of repairs to make them playable.
Mike
Offline asat
Re: First build tranny ?? (ao-44)
« Reply #2 on: February 11, 2016, 08:56:09 pm »
Thanks Mike, yeah, I agree on the Maggie, I've been working on it for a while and finally got it to play, but it needs the caps replaced and the reverb doesn't work but I think I need to mod it a bit for some gain and tone ......  pretty sure there is a killer amp in there somewhere although it doesn't have the pitch shifting tremelo like some of the more desire able Maggie's....
« Last Edit: February 11, 2016, 09:00:21 pm by asat »
« Reply #3 on: February 11, 2016, 09:00:17 pm »
There's a big difference between the AO-43 and AO-44. That PT in the AO-44 is too little for a Plexi 6V6. But you could do a Plexi 6GW8.
Offline asat
« Reply #4 on: February 11, 2016, 09:03:29 pm »
How about use the PT (24110)  from the ao-29 amp and the OT from the -44?
Offline asat
« Reply #5 on: February 11, 2016, 09:06:06 pm »
Where can I find the specs to compare these old TX,s?  I can't find anything on hammonds site....
Offline Mike_J
« Reply #6 on: February 11, 2016, 09:15:33 pm »
From the you tube post I heard it is already a great blues amp when working properly.  Best to try to get the amp working with its existing circuitry in my opinion.  John Mayer might record his next CD using one and your amp would be worth a lot of money if it is not modified.  Just my two cents worth.
Mike
« Reply #7 on: February 11, 2016, 09:20:30 pm »
If you are gonna use the PT from the AO-29 just use it's OT also. They're already paired for a push-pull 6V6 amp.
Offline asat
« Reply #8 on: February 11, 2016, 09:22:29 pm »
Mike, If that is the same post I listened to, he sent that amp to Brunswick amps and it is pretty highly modded, fender reverb, revoiced tone stack and mods for higher gain was it this one?  https://m.youtube.com/watch?v=wr3LrlAahJE
Lou
« Last Edit: February 11, 2016, 09:35:49 pm by asat »
« Reply #9 on: February 11, 2016, 09:24:46 pm »
I've never seen such a comparison. You can find a lot of schematic links to Hammond organs on Captain Foldback's website. Don't confuse Hammond organs with Hammond Manufacturing (transformers). They are not the same company.
Offline asat
« Reply #10 on: February 11, 2016, 09:25:10 pm »
OK. - I thought maybe the ao-44 OT might have been a better tranny......  guess I could always build a pee wee too!
Offline asat
« Reply #11 on: February 11, 2016, 09:30:03 pm »
[/quote]I've never seen such a comparison. You can find a lot of schematic links to Hammond organs on Captain Foldback's website. Don't confuse Hammond organs with Hammond Manufacturing (transformers). They are not the same company.
[/quote]
Ooops.    I did not know that..... :dontknow:  :laugh:  can you point me to some info so I can learn which trannys to use where so I don't have to keep bugging you guys?
« Reply #12 on: February 11, 2016, 09:45:55 pm »
AO-29 iron will build a Plexi 6V6. Or you can get an AO-43 like I did. Or you can build Hoffman's Plexi 6V6 and use the iron he sells. Or you can go to Mark Huss's website and read about the iron he used.
Offline drew
« Reply #13 on: February 12, 2016, 12:20:12 am »
I believe the -43 and -44 use the same OT: AO-24158 0.  So if the -29's is different (I don't know if it is or not), and you want to use the same one that sluckey used in his Plexi6v6, you can rob the one off the -44 that you have.
The -43's PT is no. AO-24157-1, so not the same as what you report is on your -29.  But, as sluckey points out, it will be fine to use since the -29 is a 2x6v6 amp already.
« Reply #14 on: February 12, 2016, 12:51:14 am »
build a "84" plexi.   :icon_biggrin:
6BQ5/EL84 with the AO-44 PT & OT.
