July 25, 2026, 12:36:23 pm
Hoffman Amps Forum image Author Topic: Powered Mixer without cabs?  (Read 6203 times)
Offline stratavox
« on: April 01, 2016, 09:02:37 am »
First, if this is in the wrong category, apologies. I have a Yamaha powered mixer, and would LIKE to use it as JUST a mixer. If I run from the unbalanced outs to powered cabs (both for mains and monitors), can I NOT use the main speaker outputs? Essentially running no load on the amp? The manual doesn't address this (understandably...). Thanks folks...
Re: Powered Mixer without cabs?
« Reply #1 on: April 01, 2016, 11:11:08 am »
It will be fine.
But HEAVY.
Offline stratavox
« Reply #2 on: April 01, 2016, 12:40:19 pm »
Ummm...heavy?
« Reply #3 on: April 01, 2016, 11:37:53 pm »
I bet it is 20 pounds of case and mixer, 20 pounds of power amplifier.
Typically the mix-part steals power from the power-amp part, so no simple amputation.
But I have done it, when I liked the mixer but had different needs for speaker power.
Offline stratavox
« Reply #4 on: April 02, 2016, 09:44:55 am »
Got it, and thanks again. I appreciate your time, as always....
