August 29, 2026, 02:04:55 pm
Hoffman Amps Forum image Author Topic: PT Hack .... is this possible ?  (Read 5615 times)
« on: April 16, 2016, 02:41:48 pm »
A friend has a 340v-0-340v PT that he has wind, now he would like to use it for 4 x 6v6 in PP and 340v is too much ...
he told me he want to unwound the windings till 315V but being a PT with CT I think this isn't very simple
I had an idea (assuming there is enough space for some further windings on the transformer)
the idea is to add a single 25V winding and connect it to the CT in counterphase
as to have the 25V subtracted from the 340V
Do you think this method can give the hoped results or is a crazy idea ?
BTW as load it will be better a 3.3K or 4K OT with 315V AC rectified using diodes ?
Offline VMS
Re: PT Hack .... is this possible ?
« Reply #1 on: April 16, 2016, 03:04:45 pm »
340 is not necessarily too much.
That PT and about 4k OT and you have output section similar to jim kelley amp.
« Reply #2 on: April 16, 2016, 03:09:06 pm »
Wouldn't it be easier to employ the zener-diode-on-CT trick? I also agree, 340-0-340 is not too much. Probably turn into 440 VDC under load.
« Reply #3 on: April 16, 2016, 03:49:34 pm »
340v * 1.4 = 476v
. a drop of 36v under load .... may be, but I don't know how much current is disposable on the PT
. use a zener ..... may be an amplified zener as to avoid the use of a big one
Jim Kelly amp .... is a schematic disposable ?
The reason for which I've think to the additional winding was an association of ideas as recently I discussed about to decrease the voltage on a toroidal transformer and there (single secondary without CT and no lamination to be dismounted) the thing is easy to be done
I would like to know if this method can be applied also to a CT secondary using a single addon winding connected to the CT
Offline VMS
« Reply #4 on: April 16, 2016, 03:58:54 pm »
Here is one:
http://el34world.com/charts/Schematics/files/_Miscellaneous/jimkelly_facs.pdf
Kevin O'connor has kelly project in TUT5 that uses hammond 273BX PT and 1650N OT.
« Reply #5 on: April 16, 2016, 05:32:24 pm »
Many thanks for the schematic
I've the TUT5 but forgot about this schematic
« Reply #6 on: April 16, 2016, 09:37:54 pm »
How does that work?
The two ends of the CT winding are in anti-phase. A single winding counterphase to one must be in-phase to the other.
Offline trobbins
    • Tim's projects and info
« Reply #7 on: April 16, 2016, 11:24:16 pm »
K, you would need to wind two new windings, and buck the ends of each of the 340V windings.  But that seems a horrible path to take.
A non-dissipative way to drop some B+ is to use a CLC filter, where the first C is only small (eg. 4uF poly) and L can be low (eg. 1-4H).  It does take up some space, but provides a smoother B+ ripple with less rectifier noise.  Easy to see using PSUD2.
« Reply #8 on: April 17, 2016, 01:07:00 am »
why not wind another?
« Reply #9 on: April 17, 2016, 02:56:18 am »
Yes, that way it didn't work
Yes, I see
Good I'll remember this
Seems he would like to use that, but I don't know if there is a particoular reason
Thanks to ALL
« Last Edit: April 17, 2016, 03:02:20 am by kagliostro »
