September 14, 2026, 07:30:24 am
Hoffman Amps Forum image Author Topic: Hybrid SS/Tube Bridge Full Wave Rectifier?  (Read 6282 times)
Offline okguitarman
« on: May 23, 2016, 06:46:16 pm »
 I Have a set of trans. power and output from Backstair HT5, Voltages are (386v red to red no center tap) and (18.4 center tap 18.4)
With Hybrid SS/Tube Bridge Full Wave Rectifier what voltage will I have? With 5Y3
Trying to figure out what amp to build. Amp was push pull 12BH7
I think the output is  22k/8 and 16
Re: Hybrid SS/Tube Bridge Full Wave Rectifier?
« Reply #1 on: May 23, 2016, 07:48:22 pm »
Voltages are (386v red to red no center tap) and (18.4 center tap 18.4). With Hybrid SS/Tube Bridge Full Wave Rectifier what voltage will I have?
With cap input filter, unloaded B+ will be 545VDC. How do you plan to heat the 5Y3?
Offline okguitarman
« Reply #2 on: May 23, 2016, 08:00:58 pm »
Separate tran.
Offline okguitarman
« Reply #3 on: May 23, 2016, 08:19:34 pm »
I think I was over thinking the no center tap that was the voltage I figured.
Hybrid SS/Tube Bridge Full Wave Rectifier was from your page Thank you!
Offline okguitarman
« Reply #4 on: May 23, 2016, 08:23:59 pm »
I tied the 386v to Diode rec. and got 355v
« Reply #5 on: May 23, 2016, 08:29:58 pm »
Put a capacitor on it.
No cap, you get the Average of a bump-wave. In theory 386 * 0.9 is 347V. Your 386 may be higher no-load, or your meter may mis-interpret a big bump wave. IAC, 347V==355V for any practical purpose.
With cap you get the Peak of the wave. 386 * 1.414 is 545V, what you-all are computing and expecting.
If your load is just a meter, the cap can be 0.5uFd, maybe as small as 0.1uFd, though you surely have some 10 to 100 uFd on hand. Note that 545V is a lot for many caps. e-caps tend to top out at 450V-500V. Film can be bought any voltage but we rarely buy over 400V for routine audio circuits.
« Last Edit: May 23, 2016, 08:33:42 pm by PRR »
Offline okguitarman
« Reply #6 on: May 23, 2016, 08:34:08 pm »
 Ah thank you had me scratching my head! Makes perfect sense
« Reply #7 on: May 23, 2016, 09:24:31 pm »
Thanks for making me look at that drawing. One of the diodes was drawn backwards. I've corrected it now.
Offline okguitarman
« Reply #8 on: May 23, 2016, 09:49:54 pm »
I am on a mac I wished I had visio
Offline okguitarman
« Reply #9 on: May 23, 2016, 10:03:52 pm »
What could I use that trans. for Maybe a stand alone reverb. Would the voltages work? voltage should drop when loaded.
Just looking for a new project.
« Last Edit: May 23, 2016, 10:14:32 pm by okguitarman »
