September 15, 2026, 04:44:53 am
Hoffman Amps Forum image Author Topic: AB763 lite w/o trem/rev - european version  (Read 20242 times)
Offline Guitar-Tube-1969
Re: AB763 lite w/o trem/rev - european version
« Reply #50 on: August 15, 2016, 07:30:24 am »
Do you have any advices for biasing this amp? I',m a little bit confused from the information I read...
« Reply #51 on: August 15, 2016, 10:17:15 am »
« Reply #52 on: August 16, 2016, 09:20:48 am »
Ok, thanks for the link!
I tried it, the amp was on for about 2-3 hours now. The bias values are:
1st measuring:
V3/3: 411 VDC
V3/8: 25,0mV
=> 411*0,025=10,3W
V4/3: 411 VDC
V4/8: 24,0mV
=> 411*0,024 = 9,9W
2nd measuring in between:
V3/3: 408 VDC
V3/8: 25,0mV
=> 408*0,025=10,2W
V4/3: 408 VDC
V4/8: 23,05mV
=> 408*0,0235 = 9,7W
3rd measuring at the end (same as the first):
V3/3: 411 VDC
V3/8: 25,0mV
=> 411*0,025=10,3W
V4/3: 411 VDC
V4/8: 24,0mV
=> 411*0,024 = 9,9W
Because 6V6 has a max. rating at 12W (hot), it seems ok, isn't it?
2nd question: I want to add an extension speaker jack.
The wiring of the main speaker jack at the moment is:
G: wired to the black cable from the OT and to the ground
S: wired to G
T: Green wire from R24 (820 Ohm) and green wire from OT (in my example the three wires for 4, 8, 16 Ohm goes to an impedance switch and one green cable from there to the tip)
Could I use another jack and wire it as follows?
G: wired to G of the main speaker jack
S: not connected
T: wired to the tip of the main speaker jack
Then they shoud be parallel wired and I could:
- Two 8 Ohm speakers, impedance switch at 4 Ohm
- Two 16 Ohm speakers, switch at 8 Ohm
Is that right?
« Reply #53 on: August 16, 2016, 11:06:14 am »
The info I have says a 6V6 PAMAX is 14 watts.
Your thoughts about adding a second speaker jack are correct. Just remember, if you only plug into one jack it has to be the main jack.
« Reply #54 on: August 16, 2016, 11:13:33 am »
Great, thanks!
Would you recommend to bias them a bit hotter, e.g. 12 Watt?
« Reply #55 on: August 16, 2016, 11:23:47 am »
You are biased at 70% now. That's what I have my fixed biased amps set for. But you can bias hotter if you like the sound. If so, you may have to change tubes more often.
« Reply #56 on: August 22, 2016, 01:53:00 pm »
Hey all,
I've got a problem with my power tubes. Both tubes show  a silver film at the inner glass (see attachement). The tubes were new and only have about 20h playing time. What's that?
In addition the internal speaker lets bell my rectifier tube on a certain frequency. It disappears when using an external speaker, so it seems to be a physical problem, any ideas?
Thanks - Axel
« Last Edit: August 22, 2016, 03:41:59 pm by Guitar-Tube-1969 »
« Reply #57 on: August 22, 2016, 04:42:20 pm »
(Nearly) ALL tubes have that silver splash. Yours did from new, right?
It is "getter". A monoatomic film of thirsty metals to absorb the last traces of gas inside the vacuum.
Related question:
In time (decades) the getter can turn brown. As long as there is ANY silver left, it is still doing its job. Throwing-out a tube just because its getter is 10% brown around the edges is like throwing out a soap-bar when 10% is gone (and 90% of soap is left).
« Reply #58 on: August 27, 2016, 05:35:46 am »
Great, thanks!
Do you have any idea, to prevent the tubes (either rectifier or power) to resonate at a certain frequency?
« Reply #59 on: August 27, 2016, 05:39:52 am »
Here is a final foto with faceplate and cab - Thanks to all of you!!
« Reply #60 on: August 27, 2016, 06:00:24 am »
It's possible that the particular tube just resonates (rings) at a certain frequency. Since it only does it with the internal speaker I would try another tube first. This is called sympathetic vibration. I've seen silicone rubber rings for small tubes that help. Maybe the same rings are available for larger tubes. Can you stop the ringing by holding the tube with an oven mitt or pot holder?
« Reply #61 on: August 27, 2016, 06:01:44 am »
That amp turned out very nice!  :thumbsup:
« Reply #62 on: August 27, 2016, 12:06:34 pm »
Hi Sluckey,
sorry for my delayed answer but we play a short gig and I used the amp. Sounds good!
To the resonance problem: The ringing stops when I'm holding the tube. It stops too when using an external cab only. So it seems to be a physical problem, isn't it?
Axel
« Reply #63 on: August 27, 2016, 12:07:02 pm »
and: thanks for your compliment!!
« Reply #64 on: September 04, 2016, 09:03:38 am »
Hey all!
I've uploaded a video on youtube with a clean sound example (first solo, at 1:40 with a backing track). The video contains some photos from the final assembly.
Have fun - Axel
https://www.youtube.com/watch?v=j9rUS5LV6r4
« Reply #65 on: September 04, 2016, 09:12:54 am »
Nice playing! Did those rings on the octal tubes solve the 'ringing' problem?
« Reply #66 on: September 04, 2016, 09:16:01 am »
Thanks.
To be honest, I'm not sure. I've changed the rectifier and power tubes to JJs and did not check it without the rings. The is no ringing at all the moment and I'm happy.
