July 25, 2026, 11:07:18 pm
Hoffman Amps Forum image Author Topic: Fender Champ OT  (Read 4899 times)
Offline basschops1528
  • --Amateur audio electronics guy--
Fender Champ OT
« on: June 28, 2016, 07:01:46 pm »
Hey Guys,
I'm getting ready to buy my final bunch of Revibe parts along with parts for a Champ. I'm looking at OT's and PT's on Tube Depot and Hoffmans page and saw that the depot sells a classic tone version rated 5 watts. Am I gonna blow that thing with a cranked Champ? I'm all for saving money but how well is this thing gonna perform against Hoffmans several OT's for this type of amp; how do they compare against themselves? The depot only sells the one (https://tubedepot.com/products/blackface-champ-output-transformer).
Now how about PT's? Here's the depots (https://tubedepot.com/products/blackface-princeton-champ-power-transformer), the hottest of the three. 125P1B 5V/pk less, and the MOJO759 35V/pk less than THAT.
Maybe this can help. I'm looking to build a Champ that can be played clean but has great breakup for that Clapton/Blues sound. I'm going to be using a J J 5Y3 (any good? Voltage drop?) as well and maybe an adjustable NFB pot. Any ideas what OT/PT combo would be good?
« Last Edit: June 28, 2016, 07:13:06 pm by basschops1528 »
Johnny D
Re: Fender Champ OT
« Reply #1 on: June 28, 2016, 08:57:49 pm »
If you look at the revibe schematic - verb section, it's basically a champ, so the OT should be the same in both.  Part of the Champs *sound* comes from the slightly anemic OT, so if you *beef* it up, it may change, *that sound*
Re: Fender Champ OT
« Reply #2 on: June 28, 2016, 09:07:56 pm »
No. OTs get muddy, not hot.
Note that TD is showing zero stock.
Re: Fender Champ OT
« Reply #3 on: June 28, 2016, 09:09:59 pm »
Muddy sounds not good. I'll go with Doug's. Now how about the PT? More or less volts for the sound I'm looking for? It's a 5F1 so resistor sag and early breakup.
Johnny D
Offline Paul1453
Re: Fender Champ OT
« Reply #4 on: July 02, 2016, 10:49:09 am »
Just to give you an idea about my cheesy BB set-up.
Then to maybe ease your mind on little SE OTs.
That is a working 12AX7 - EL34 amp on my BB there.
I know it's hard to believe that mess works.   :l2:
It is using one of my tiny SE OTs, with the EL34 putting out around 9W.
For comparison I've included the 1 Hammond 8W 125CSE I bought new for almost $50.
These tiny OTs sound fine to me with these simple, low voltage, SE 6L6 and EL34 circuits.
So I wouldn't obsess too much about the OT you use on your Champ.
I'm sure whatever one you choose will sound good to you.   :icon_biggrin:
« Last Edit: July 02, 2016, 10:57:56 am by Paul1453 »
