September 08, 2026, 11:23:05 am
Hoffman Amps Forum image Author Topic: guitar ?'s  (Read 5313 times)
guitar ?'s
« on: July 25, 2016, 05:48:49 pm »
 started *this* thread here;
http://el34world.com/Forum/index.php?topic=20611.0
Thinking I had an amp problem, with a little help from my friends, I'm where I need to be;
I found "the problem", (attached pic), well a problem, trip to the guitar store should fix that.
The other pic has a ground wire under the bridge?, no physical connection, just screw pressure, is that a *normal* set-up?
The last pic is the pot wiring, when I ohm'd the pot, wiper to Input (pickup), I got 2.5-125k-0.   :dontknow:
Is that pot taper, or because I left the pickup attached and it's lo-ohms to ground?
Re: guitar ?'s
« Reply #1 on: July 25, 2016, 06:49:54 pm »
1.  I found "the problem", (attached pic), well a problem, trip to the guitar store should fix that :thumbsup:
2.  The other pic has a ground wire under the bridge?, no physical connection, just screw pressure, is that a *normal* set-up? I've seen that done with Fender Bass guitars.
3.  The last pic is the pot wiring, when I ohm'd the pot, wiper to Input (pickup). . .   I never trust a pot or resistor reading if it's in circuit with other components.
Re: guitar ?'s
« Reply #2 on: July 25, 2016, 07:41:12 pm »
Rookie mistake, though I blame it on the South, because everyone is running AC, all that outputted heat has forced the Jetstream to bring it up North, it was 90deg, 90%humid, my brain was frying inside my skull :icon_biggrin:
new values using ground for - wiper +, 2-125k-8.5k
Re: guitar ?'s
« Reply #3 on: August 03, 2016, 08:40:57 am »
So I replaced the saddle, fixed a couple iffy wires, the top bass string is still weird.  the guitar has a single bridge pickup, well 2 pickups together, with only 2 wires.   Can I just rotate it 180 so the coil on the top string now picks up the bottom string?  Is there a *critical* distance from strings, or just personal preference?
thanks
